Question about GE Refrigerators
Small drip out of ice maker. Ice cubes dump out of ice maker are sort of siamese. I.E., they are chained together by a tiny amount of ice.
    Scholar:
  • 116 Answers
You are getting too much water to your icemaker, either faulty water valve or extremely high pressure or extremely low pressure either way will cause too much water in your icemaker, extreme low causes water valve not to shut off, high pressure lets too much water through when it opens. These pressures are not adjustable in the fridge. You can on certain models adjust the amount of time the valve is on, per the icemaker, it usually will have a screw on the side of it towards the front of the icemaker.
Sean
Posted on Mar 27, 2011
  • Betty Johnston Mar 30, 2011
    Sean,
    Thank you for your reply. I am still currently in the investigation stages which has included:
    Pulling the unit away from the wall, vacuuming everything that I could get to, removing the inlet valve to ATTEMPT to perform an OHMS test. I have an inexpensive analog multimeter with only one setting for OHMS which is X1K. I know that it means to multiply the reading by 1000 to get the results. However since I am a newbie at multimeters I don't know if my interpretation is correct or not. I'm thinking of walking into Radio Shack to see what they say, or perhaps, visiting the library and trying to research there.
    I have followed the instructions to calibrate the OHMS to zero - that works. Then I placed the probes on the metal tabs-the set on the water only side and the set on the water to icemaker side.
    I know I should use the green color scale. The probes are plugged in as follows: black into the COM side and red into the OHM side. What's confusing me is the numbers and "tick" marks on the multimeter. Here is a crude representation of part of the meter markings:
    3 2 1 0
    | l | l l l l | l l l l | On the water only side the needle goes to the VERY FIRST tick mark after the zero. On the icemaker water supply the needle is between the zero and the first tick mark. I know that the OHMS should be between 200 and 500 for each side. If I am interpreting this correctly, then the tick marks between the numbers represent 20%. So by multiplying .20 x 1000 it comes out to 200 for the water only side and not enough for the icemaker side which is nearly at zero. While I had the valve out I examined it for debris and couldn't see anything. I also flushed out the steel braided line that leads from the shut off valve in the wall. I also performed a water pressure test at the ice/water dispenser door as per GEs instructions. Twenty seconds should yield a minimum of 13.2 ounces. The water is flowing at a rate of 1 ounce per second. (I got 20 ounces in twenty seconds). But of course that is only testing the water side of the valve. If my interpretations of the multimeter is correct, then I think I need a new valve because it appears that the water side is meeting minimum and the icemaker side is failing to meet minimum. Also, I didn't notice it before but the ice cubes are hollow.
  • Sean Miller Mar 30, 2011
    HI sounds like you are getting into this! I'm not actually sure on the ohms but 200-500 is a huge gap and sounds way too high, 20-50 sounds more likely, second if your getting any water at all the chances of the coil in the valve being bad is slim, so your ohm reading will probably be right. I am not familiar with your specific type of meter so i cannot help you there, but icemaker assemblies are usually very simple, if you have good pressure its either the icemaker or the valve, from what your telling me its a bad valve, they run about $30-70.00. This will take care of your problem. I'm curious to know where found these ohm readings did you get them from the wiring diagram?
What causes my ice maker to drip water?
HI,
This could be either the ice maker is old and the finish inside has depleted, the water valve is going bad or you had a jammed ice cube and now it overfilled. Many different reason this could happen. Does the ice cubes stick together with a bridge? Is the drip coming from the ice maker head unit? How is the ice in the pan its stored in, stuck together? In the pan, has the ice glaciered together? Need more information please. Thanks
Aug 09, 2014 | Kenmore Top Freezer Refrigerator
Water works on door but ice maker isn't making ice occasionally hear noise like trying to dump ice cubes but no ice
the water valve located on the back of the refrigerator that the water line is connected to could be bad. if no water is coming to the ice maker then it shouldn't have any ice or water in the ice mold. if it is empty you can try pouring enough water in the mold to make ice cubes. wait an hour or so and see if the ice maker dumps the ice. if it does you probably have a bad water valve.
if your ice maker has ice in it but had been making small cubes you should check to make sure you don't have a jam. small cubes could be from low water pressure or a blockage. if your refrigerator has a water filter it may be time to replace it if the water dispenser water pressure is also low.
May 28, 2010 | Hotpoint HSM25GFRSA
Excess water delivered to ice maker
That will depend on type of ice maker and model number of refrigerator. At times the water control valve will stick because of age or just leaking while off like a dripping faucet. Can you find model number of your whirlpool? I do have some repair manuals for ice makers if they are not the electronic type. Sea Breeze
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice is dumped before totally frozen.
Sounds like a water valve problem. The hollow ice cubes are the giveaway. This means not enough water. only things it can be is the ice maker is not turning on the water valve long enough or the water valve is restricted or the water valve has been leaking and has frozen the fill tube. and is only leting out a small amount of water in this case as well you will still need a new water valve.
start with water valve and if that does not solve the problem you will need to replace the ice maker.
Jan 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Jan 02, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
131 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
