Question about GE GBS18KBM Bottom Freezer Refrigerator
Ice builds up at bottom drain. fan stops and entire unit quits cooling
    Scholar:
  • 116 Answers
This is a clogged defrost drain, this unit its fairly difficult to clean and get to, its either clogged with ice or debris but i would recommend service unless you are fairly used to repairing appliances and such.
Sean
Posted on Mar 27, 2011
  • 1 more comment
  • mark74639 Mar 28, 2011
    Drain has been thawed many times. It is always clean. works two weeks until it ice's up again and stops fan blade, causing entire unit to not cool. Did GE put out a bulletin on this
  • Sean Miller Mar 28, 2011
    No bulletins, you can buy a drain heater, they got another name for it but its not actually a heater is a little metal bar that you hangs off the defrost heater and down into the drain that warms it up to keep this from happening but no i've never seen a bulletin on it.
    Sean
    Also it sounds to me like its not getting thawed all the way, you need to physicall verify that its draining water down the defrost drain from inside the freezer if you dont see that then its not competely thawed.
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
There is water under my drawers with ice build up. I clean it up and 2 weeks later it wet again. Help
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
May 15, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Mar 16, 2010 | LG LFX25960ST Stainless Steel French Door...
We Just moved into a house that has a GE profile bottom freezer with brita in it. We have a problem with ice build up on fridge floor under crisper and its causing us to loose produce in the crisper. Any...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 17, 2010 | GE GBS22HCP Bottom Freezer Refrigerator
Bottom of freezer has build up of water,which turns to ice.Freezer is on bottom with ice maker,but no sign of problem with ice maker.Could it be seal(gasket) of freezer door?Thankyou for you help.
Sep 15, 2009 | Refrigerators
The freezer has water and ice leaking in the
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frigidaire bottom freezer building up ice. Where
Aug 21, 2009 | Refrigerators
Water leaking/freezing in bottom of freezer
Jul 12, 2009 | KitchenAid KSRA25ILWH / KSRA25ILBT /...
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GBS18KBM Bottom Freezer Refrigerator Logo
69 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
