Question about Panasonic NN-H275 Microwave Oven
The top right corner of my panasonic nn-h275 otr microwave door leaves a approx. 3cm gap when closed. Fixable? Dangerous?
  • Panasonic Master
  • 6,771 Answers
If the door is warped cheaper to replace the whole oven, the 3cm gap is a hazard because you have dangerous radiation leakage, the levels are exceeding safety standards and should be removed from service immediately.
Posted on Mar 27, 2011
Panasonic microwave model NN-H275: Oven door doesn't open; Makes crackling or arcing sound when turned on;
If you do not see actual arcing in the cavity making the noise it is probably components on the inverter. Too exppensive to repair. Get a new one. Dont like or trust the inverters.
Jun 25, 2017 | Panasonic Microwave Ovens
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
Panasonic NN SD277W
The internal fuse has blown indicating a secondary problem, it may be one of the door switches is defective or a more serious issue.
Jun 02, 2012 | Panasonic NN-H275 Microwave Oven
Shuts off after 4 seconds and plate does not turn
The problem is most likely caused by 1 or 2 bad door switces often the result of food partical build up, the latches will need to be replaced.
Mar 13, 2012 | Panasonic NN-H275 Microwave Oven
How do i remove the control panel
Hi Colin, On our microwave , unplug first, husband just removed thewhole outer casing of microwave and pushed the button through the back, he did not touch the control panel. Hope this helpskind regardsChristine
Nov 20, 2011 | Panasonic NN-H275 Microwave Oven
Door button does not function for panasonic microwave=need to know how to take the face off so that I can fix it
Take side panels off and press the button through from the back, my husband has just done this tonight on our Panasonic microwave model NN-ST477 as the door would not open. He found a piece of plastic like a hook had snapped off. The door now opens and functions normally. Took about 30 minutes to do . If and when it becomes stuck again we know that we will need a new replacement button. Hope this helpskind regardsChristine
Sep 14, 2011 | Panasonic NN-H275 Microwave Oven
Panasonic Inverter Microwave - plate stopped turning
panasnic nn st557w does not respond when i press start button
Oct 13, 2010 | Panasonic NN-H275 Microwave Oven
Can not open the door
Hello :
That could happen because of bad door switches . I don't think that there's anything you can do by yourself unless you are a handy . Calling for repair is better suggestion . A microwave is capable of giving you a serious electric shock even when it's unplugged from the outlet .
good luck .
please rate !
Apr 02, 2010 | Panasonic NN-H275 Microwave Oven
Cracked door on Panasonic S753 combi microwave oven
Hi I have a Panasonic combi oven in between the glass door is misting up should I be worried
Jan 07, 2009 | Panasonic NN-S753 Microwave Oven
Panasonic NN-H275 Microwave Oven Logo
120 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
