Question about Audiovox AV1510D (Brand ) Car In-Dash Multimedia Unit with Motorized Flip-Out 7-Inch Widescreen L... Car Video Player
Were can i buy a wire harness plug @ - Audiovox AV1510D (Brand ) Car In-Dash Multimedia Unit with Motorized Flip-Out 7-Inch Widescreen L... Car Video Player
  • 902 Answers
Ebay, walmart. i would go thru amazon.com tho you can select your car model and they will send you the wire harness you need that will literally be plug and play instead of having to cut wire and put them all together.
Posted on Mar 27, 2011
Clarion cz301e
You can purchase a harness adapter that will plug into the original radios harness. The other end of the adapter harness has loose wires with tinned ends which you connect to the new radio's harness, which as the same colors as the adapter wires.
  • Metra Model: 70-8901 is one adapter that I believe will work.
  • Scosche item Number: 16845632 is another adapter.
  • If you want to buy locally, Best Buy will probably have one or the other. If you want to buy on line, just do a search for the name and model numbers.
Subaru ForesterReceiver Wiring Harness
May 12, 2014 | 04-05 Sg5 Front Lip Ds-Style Urethane
I need a wiring diagram for a 82harley sportster
http://www.ebay.com/itm/HARLEY-DAVIDSON-SPORTSTER-MAIN-INTERCONNECT-WIRING-HARNESS-70482-07-/161682525353?hash=item25a5078ca9&vxp=mtr
why cant you buy one???,there are alot of them for sale,or by the headlight harness only,
HARLEY FL FX SPORTSTER HEADLIGHT CONNECTOR PLUG 3 post CHOPPER BUILD
Jan 01, 2013 | Harley Davidson XLH 1000 Sportster...
I need the stereo wiring diagram for a 2003 F150 so I can install an aftermarket Pioneer cd player, can you help me out? Thanks!
go to the electronic store such as Best Buy or simuliar and buy the wire harness that plugs in the factory plug in and then just connect the same color wires to the stereo wire harness
Mar 24, 2011 | Ford F-150 Cars & Trucks
I want to change my original cd player for a pioneer
This is because you need to purchase the aftermarket-oem harness plug.This harness plugs into your original equipment radio harness and allows you to plug any aftermarket radio into the stock deck wires.After you plug the harness in you can then connect the radio wires together.Your local autoparts store or circuit city or best buy or audio express will have these radio conversion plugs.I hope I could help
Dec 24, 2009 | 2003 Ford Explorer
I need to know which colour wire from the radio is for what, so i can fit a non standard stereo
My best advise is not to cut the stock wire harness plug. Go online or to your local best buy and buy a wiring harness that will plug into your stock plug and into the radio. then you don't need to know what any wires are. cutting the stock harness is opening a can of worms.
Dec 23, 2009 | Car Audio & Video
Need help installing electric trailer brake controller
easiest way is to also buy the wiring adapter almost all elect brake units sell a vehicle specific wire harness that u unplug brake wire harness plug in other harness than plug in brake harness and just connect the wires to elect brake controller eliminates cutting and splicing ur brake harness about $18
Oct 25, 2009 | 1999 GMC Savana
I have a 1995 Grand Jeep Cherokee Larado I'm putting in an after market stereo. It has an infinity gold system and amplifier. I can't get any sound out of it and can't figure out which wire to connect the...
a good way to find out is, if your lucky- you still have the plug connected to the wires in your dash. Buy a wiring harness from a place like Best Buy. The harness, when plugged in to your factory harness will have its blue wire in line with the factory amp wire. There also may be a Blue wire with white stripe, this also needs to be connected to the blue wire if the above doesn't work. If you dont have a factory plug anymore- bigger problem. brian.small@bobstgroup.com
Sep 05, 2009 | Car Audio & Video
Trailer harness
You buy a plug-in trailer wiring harness for this vehicle. I bought mine at NAPA. The vehicle harness plug is in the wiring stuffed behind that LR access panel wherin the car jack sits. You may have to actually remove the LR tail light assembly to discover the plug, but it's there. The wiring harness is a bit pricey, more than the usual DIY harness, but it makes for a very clean, flawless, and effortless connection.
Jul 12, 2009 | 2002 Suzuki Vitara
Installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Nov 21, 2008 | 2000 Pontiac Grand Prix
Car Audio & Video Logo
116 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
