We had a power surge at our house this morning. Since then all appliances are running fine except the tv. We have a Phillips Magnavox 35 inch model #TS3654 C102. Chassis # is 36Z500-7563. It will not power up. I have plugged it into other outlets to make sure that the outlet wasn't the problem. The surge bar that it was plugged into is fine and all other items such as the satellite box and the surround sound system are fine.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Try the circuit breaker and unplug and replug it in my TV does this sometimes
Posted on Jul 12, 2017
SOURCE:
  • 1139 Answers
SOURCE: Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
Posted on Sep 24, 2007
SOURCE: will not turn on
I have an RCA projection widescreen TV model # D52W19B and was watching when it made a pop noise and turned itself off. Now when you try and turn on you get a high pitch beep but TV keeps shutting itself off with no picture or anything. Could this be the bulb went bad?
Posted on Jan 14, 2008
  • 7 Answers
SOURCE: Power won't turn on
The microprocessor in the keypad probably needs to be reset. With the unit unplugged, remove the keypad housing (one screw in back, one on the left side, rock it up enough to get a small screwdriver inside, then push back the soft plastic fingers to release the housing -- force it a bit, you won't break it). You do not need to remove the bottom cover.
Remove the keypad cover (4 screws) and the PC board (one screw). You'll see a factory reset button near the middle of the left side. Press and hold that for a couple of seconds.
If you want to test the unit before re-assembly, hold the PC board so it doesn't short against anything (there's nothing more than 5v on the board, so you won't get shocked), and plug the unit in. The display should appear. Unplug the unit, re-assemble, and then bake some bread!
There is also the possibility that the backup battery on this PC board is bad. Check it with a voltmeter -- it should be about 5v.
Posted on Jan 26, 2008
  • 234 Answers
SOURCE: Totally lost power to HP 7110
Don't Worry the HP printer are deisgned to connect without the surg protector.
Try the steps mentioned bellow
Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One. and wait for atleast 1Min
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
If This does not work in the power cord you will see a rectangle box like thing thats a apdptor, after plugging it to the power oulet for a couple of minitues, check and see if you can feel any heat in the adaptor if yes then the adaptor is good the power cord may be bad, so accordingly replce the power cord or adaptor:
For HP Parts check the link bellow:
http://partsurfer.hp.com/cgi-bin/spi/main
Good Luck
Posted on Oct 03, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Posted on Feb 04, 2009
Hello, I have a Magnavox tv 32" model 32mt3305/17.
you should bye a surge potecter power cord.surges happens all the time and destroys electronics
Aug 17, 2013 | Philips Magnavox 27MS343S 27" TV
Just curious as to how much a philips magnavox motherboard would cost for a 32 inch tv.. installation included
Need the model number of the set to even begin to answer your question since there are so many different Phillips 32 inch models and they all have different components and circuit board designs.
Jun 18, 2011 | Philips Magnavox 51MP392H Rear Projection...
Grey lines
this a vertical circuit, and HV Circuit Defective, send to repair
Jan 15, 2010 | Philips Magnavox 27MS343S 27" TV
Phillips magnavox
Could be an open internal fuse or power supply failure
Mar 18, 2017 | Philips Televison & Video
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox projection TV
you will need to change the convergence ICs both of them STK-392-120 they will cost about 15.00 each if you can solder you can do this repair yourself in a hour. A shop usually gets around 450 to do this repair. Let me know if you need further info.
Mar 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
TV seems to be "stuck" in VCR mode after power surge
your tv is playing dvd means your video &sound section is ok. as it is not playing cable means that there a problem in tuner section only. if cable connection &its socket is ok.
Sep 25, 2007 | Philips TS2768C 27" TV
My TV died this morning
Sounds like a power issue with the unit you will have to call the customer suppport line and have them refer you to an authorized dealer or send it back to them.
Aug 06, 2007 | Emerson EWL3706 37 in. LCD Television
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Ekse
