Question about Whirlpool Duet GHW9150P Front Load Washer
The washer does not spin at all would that be the mcu or drive motor If its the drive motor what should i be looking for to tell if something is wrong with it?
    Sergeant:
    Champion:
  • 202 Answers
Hi... You have a bad motor control board... Motors and door locks on whirlpool duets never go bad
Posted on Mar 28, 2011
We get an F6 message sometimes when the spin cycle is supposed to come on? any ideas
F6 = The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after three minutes.
1. Verify the shipping system including shipping bolts, spacers and cables are removed. 2. Unplug washer or disconnect power. 3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU). 4. Plug in washer or reconnect power. 5. Check the MCU by looking for operations of the drive motor. 6. Check the drive motor for powered rotations.
Apr 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the code f17 mean? I've had it happen twice, according to the mannual, I cancel the wash cycle and select drain and spin. Why does this happen? I have a less than a year old front loader Kenmore...
F7
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Generally if everything checks good, you'll want to replace the MCU because it's not reading the motor correctly.
Mar 19, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool awm 8143 doesn't stop at the end of the spin cycle. Instead it clicks for a while when the timer displays 1 minute then displays F07 then goes back to wash cycle. While googling I found something...
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2010 | Whirlpool AWM8123 Front Load Washer
3 year old Whirlpool Duet - F07 error showing up 98% of the time on high spin; 70% of time on medium & low spin. Checked conections between MCU & CCU. Should I buy a new MCU or a new washer?
No do the following:
  • Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
  • Check the Drive Motor
  • Check the Wire Harness
If the wiring is definitely OK and the drive motor is OK then the MCU is most likely to be the culprit.
Dec 30, 2009 | Whirlpool GHW9100L Front Load Washer
I have a F25 code pop up and it will not spin
If this is the washer and not the dryer then error code:
F25 = DRIVE MOTOR TACHOMETER ERROR
This is a major error you can try some of the items listed below?
shuts down. If a failure occurs during high-speed spin, the door unlocks
after 3 minutes.
cables are removed.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet front loading washer has a code 06. When I turn off and unplugged for 1 min. then tried to start it again, it started filling with water then stopped and started beeping the code again. I did this...
This is a Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
Make sure the wash load is not too heavy and do not move the washer when it is powered on.
If the error persists then the normal process is to check the following:
  1. Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
  2. Check the Drive Motor.
  3. Check the MCU
  4. Check the Wire Harness
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F07-AWM 9000
The F07 indicates a Motor Control Unit (MCU) Error.
  1. Disconnect mains power and unplug unit.
  2. Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  3. Check the MCU
  4. Check the Drive Motor
  5. Check the Wire Harness
  6. Reconnect power and plug unit in.
  7. Check the MCU operation by looking for movement of the drive motor, and check drive motor for fully powered rotation.
  8. Replace failed component. Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Select PAUSE/CANCEL twice to cancel the cycle.
Select DRAIN/SPIN if there is excessive water in the washer.
Re select cycle and select HOLD TO START.
Oct 26, 2009 | Whirlpool AWM9000 Front Load Washer
Hi, I have a whirlpool 6th sense washer and no manual, could you please tell me what f-06 means.. its just going straight to spin
Hi. This is a Drive motor tachometer error. The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
The potential Causes are below:
• Check wire harness connections between the Drive Motor/Tachometer and the MotorControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the MCU
***((The most likely culprit will be a failed wiring harness, but the uncommon problem will be a failed MCU))
Sep 02, 2009 | Whirlpool Washing Machines
Machine is blinking f25 in time window
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fagor, washer dryer , model 2F-3611 flashing code F07 can you tell me what this is please
Jun 12, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal De
