Question about Epson Perfection V500 Flatbed Scanner
My Epson V500 is being difficult. It seems to function fine in the fully auto mode, but that's not much use to me. In the Home mode, it scans the images but cannot make the last step of saving them. In the Professionsl mode -- the one I use -- here's the problem: I initiate the scan and the light under the scanner bed comes on. The light shuffles back and forth an inch or so, the scanner makes all the right sort of noises, then it sits there with the light on but not moving. It will do a preview scan in Professional and the other modes. I hope it's not a terminal issue; I can't afford to replace it!
  • rruttan Mar 28, 2011
    Thanks for the ideas -- but I had tried them already & no luck. I tried them again anyway, but still no luck. It's sitting there right now with the light on but the light's not moving. The green light on the front of the scanner is blinking and the dialogue box on my computer thinks a scan is being done; it's giving me the amount of time left and the green bar shows progress. But, it's not doing anything except turning the scan light on.
    Rob
  • Bern Shanfield
    Bern Shanfield Feb 17, 2013
    Old post but I just fixed this issue by plugging the scanner directly into my iMac rather than thru my usb hub. Check that if you are using a hub.
  • 902 Answers
It doesnt sound like a terminal issue it sounds like a driver issue i would re install the drivers and software (if yuou lost the disk you can download it from epson) also keep your scanner unplugged for about 10 minutes to reset it
Posted on Mar 27, 2011
  • brian shevack Mar 28, 2011
    did that help sir?
    sounds like the actual firmware on the scanner may be bad. id hesitate to go as far and say the scanner is bad because you can scan in other modes in some ways. very odd did more research for you and have not found anyone else or had anything remotely similar to this issue
I have a new epson V500. I can't get it to
Hi Make sure you are in professional mode, and make sure that you have the thumbnail view ticked, bottom left hand corner lo the proffesional mode screen, hope this works
Aug 21, 2011 | Epson Perfection V500 Flatbed Scanner
Can you scan photos on the Epson DX6000 and save the image to the computor? If possible how do I go about it?
Starting a Scan With EPSON Scan If you want to scan an image and save it directly to a file, you can start EPSON Scan as a “standalone” program.
step_1.gif Place your document or photo on the scanner. See Placing Documents or Photos for instructions.
step_2.gif Do one of the following to start EPSON Scan:
    Windows:
    Double-click the EPSON Scan icon on your desktop.
    Or select Start > All Programs or Programs > EPSON Scan > EPSON Scan.
    Mac OS X:
    Open the Applications folder and click the EPSON Scan icon.
    The EPSON Scan window appears.
step_3.gif If the Mode setting in the upper right corner of the window is set to Full Auto Mode, click the Scan button. For instructions on selecting optional settings, see Using Full Auto Mode.
01.gif mark_no.gif Note: 01.gif 01.gif To change scan modes, see Changing the Scan Mode.
step_4.gif The File Save Settings window appears. For instructions on selecting options, see Selecting File Save Settings.
cj35003e.gif step_5.gif When you are finished selecting File Save Settings, click OK. EPSON Scan starts scanning in Full Auto Mode.
step_6.gif The scanned image is automatically saved in the specified location.
    If the Open image folder after scanning checkbox is selected in the File Save Settings window, Windows Explorer or the Macintosh Finder automatically opens to the folder where the scanned image was saved.
Please follow this link for same manual with screenshots:
http://support.epson-europe.com/onlineguides/en/dx6000/html_s/scan1_1.htm
Hope it helped.
Nov 22, 2009 | Epson Stylus CX6000 All-In-One InkJet...
EPSON V500 trying to scan 2.25 x 6.5 transparancy
its possible they are right, But try puting acoulpe of sheets of plain white paper behind the transparency before copying as a buffer . The scanner is seeing the transparency reflected back causing distortion. with the paper blocking the reflection, it should scan perfectly
Jul 11, 2009 | Xante Accel-a-Writer 4N Laser Printer
Epson v500 not able to scan negatives! When I open uop the software, they don't even give me the option to scan negatives, just photos!
You probably need to reset (not reload) the scanner software. Start the Epson scan software. Select professional mode from the pull down menu (it lets you choose between auto, home and professional.) On the next screen select at the very bottom select configuration. The next screen should have 4 tabs, select other. The at the bottom (I think) select restore to factory defaults. This will reset your software, now you can use auto mode if you want it to make all your selections or home if you want some control or professional if you want to control everything. Don't forget to use your film holder that came with the unit and remove the white cover that is locked underneath the lid that covers the film illumination bulb.
Jul 07, 2009 | Epson Perfection V500 Flatbed Scanner
I want to scan a document to my computer
have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
Overview of the Basic Procedure
This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
Make sure the CX6600's power cord is plugged in.
Place your materials on the document table.
Start a TWAIN-compliant application.
In the application, open EPSON Scan.
Full Auto Mode:
EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
Home Mode or Professional Mode:
Make settings to optimize images and click Scan.
The scanned images are sent to the application.
Save the scanned images in the application.
Scanning / How to Scan
Scanning an Image
Turning on the CX6600
Placing your materials on the document table
Starting the software and scanning an image
EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
Note:
You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
Note for Macintosh users:
Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
Caution:
Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
Before turning on the CX6600, make sure it is connected to your computer.
Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
You can start EPSON Scan in the following ways.
* Start EPSON Scan directly as a stand alone application
* Start EPSON Scan from a TWAIN-compliant application
This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
Note; if you are using Windows 98:
ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
Start ArcSoft PhotoImpression.
For Windows users:
Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
For Macintosh users:
Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
Click the Camera/Scanner button.
Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
Note for Windows XP users:
Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
EPSON Scan automatically previews the image, and recognizes the document source and type.
If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
Caution:
Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
Note:
Be aware that clicking Cancel on this screen closes EPSON Scan.
The scanned image is sent to ArcSoft PhotoImpression.
Note:
* Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
* When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
May 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
By using the epson v500 photo I get the following massage: "Please remove the document mat and/or close the document cover" Off course I remove the mat and de document cover is close. I send the scanner to...
Possible driver issue. You have to reload the twain driver.
To uninstall the twain driver, please follow the ff instructions:
- Trash epson scan and epson scanner monitor from the harddrive
- Go to the library, then application support. Trash epson scanner module.
- Go to the library again, then image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on the name of your computer. Click on library, then preferences, then epson. Trash epson scan.
Empty the trash and restart your mac.
When your mac is fully back on. Go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=23&y=13 and you are now ready to install the Scanner Driver and EPSON Scan Utility v3.27.
May 03, 2009 | Epson Perfection V500 Flatbed Scanner
How to scan on an Epson Stylus DX4400
To scan an image into your PC you need to use a piece of software called the Epson Scan Utility. This
comes on the installation CD with the printer but if you don't have the CD it can be downloaded from
Epson Support. For Europe:
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=0ccCGROWIYM58zV3pqc84YT0DcLI1RrpNUFXBv2
99cYU003D
Or US:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
Once it is installed it will put an icon on the desktop, or (if you have Windows) a folder in the Start
menu. Turn the printer on and start the Epson Scan utility (it doesn't work if the printer is off), it
can be used in 3 modes: Fully Auto, Home Use or proffessional. Fully auto is the simplest, just click
on the scan button. For the others be brave and experiment!
Please take a moment to rate this solution, thanks.
Apr 09, 2009 | Epson Office Equipment & Supplies
Scanning on an epson dx4400
To scan a picture into your PC you will need the Epson Scan program installed on the PC. This program comes on the CD with the printer, but if you don't have the CD it can be downloaded from Epson:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cxyWBIk5wgudexhHWUK6Mnk&tc=6#19
It may already be installed, if you have Windows go to the Start menu and look for Epson Scan Utility. Turn the printer on and place your photo on the glass under the scanner cover. Click on Epson scan and you can choose 3 methods. Fully automatic, home mode or proffessional mode. fully automatic is the simplest method, simply click on the scan button. For the others be brave and experiment!
Hope this helps, please take a moment to rate this solution. Thanks.
Mar 31, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Scan slides
Here's a link. This will show you how to scan slides. Good luck & have fun. If this helps you plz rate this as 'fixa'. If you need further assistance leave a comment & I'll be happy to help. Thank you kindly.
http://files.support.epson.com/htmldocs/prv5ph/prv5phug/p05.htm
Mar 19, 2009 | Epson Perfection V500 Flatbed Scanner
Epson Perfection V500 Flatbed Scanner Logo
90 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
