Question about GE Spacemaker JVM1640SJ Microwave Oven
My GE microwave model #JVM1640WB microwave stopped heating and is making a humming noise. Everything else about it is fine. Light, keypad, turntable, all work normally. Just no heat. How do I install a new magnetron in the microwave? Can you give me step-by-step instructions? Thank you!
  • 56 Answers
Hello, installing is quite straight forward if you know what youre doing. BUT, be very careful of the voltage in the capacitor even when its off,it is lethal! When you change the magnetron it is advisable that you also change the diodes. Again make sure that the capacitor is fully discharged, by switching the microwave off, unplugging it, and discharging the capacitor with an insulated screwdriver, it will be noisy. Next unsolder the old diodes and fit the new ones(check their polarity). Replace the magnetron and when all looks good,switch it on. If it works, good, if not there could be a power supply problem. 9 times out of 10 its the magnetron. Good luck.
Posted on Mar 27, 2011
Microwave keeps beeping on GE spacesaver JVM1640WB
Does the display say anything?
If it says "F3" then you have a shorted keypad.
Please post a new question with full model number and more detailed symptoms.
Nov 29, 2012 | Microwave Ovens
Ge jvm1650wb005
one of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Jul 28, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE microwave model number JVM230WV 001 popped while cooking now when turned on it will only make a humming noise. Light comes on but no heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Model JVM 1870 stopped heating, all else works (timer)
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
ggk
Nov 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave stopped heating
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Nov 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge jvm1650wb005
Mar 31, 2008 | GE JVM1650 1000 Watts Microwave Oven
Loud humming/no heating
Word has it that many of these models have a defect which causes the microwave energy to be reflected back to the magnetron, causing damage to the magnetron, and eventually damaging the high-voltage diode too. Also, the fuse or the magnetron theral cutout / thermostat can eventually blow, too. There is a replacement magnetron and stirrer kit available. I would definitely call the GE Answer Center at 800-626-2005 about this. It's not considered a recall, but a "campaign". They may pick up part of the cost. It's not cheap.
Dec 31, 2006 | GE JVM1440 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
300 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
