Question about Intermatic Inc. ST01C Digital In-Wall Timer
Need info.regardind wall timer how to set and program
Open following links to identify timer and download manual
http://waterheatertimer.org/ST01C-program.html
http://waterheatertimer.org/Programmable.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 28, 2011
It does not turn off why
Unknown if this is new ST01C timer, or older timer that worked before and stopped working.
Add a comment with more information if needed.
Timer can be defective. Battery can be low. Wiring is wrong. Timer programming has overlaps and conflicts. Program 1 is set but program 2 is not set. No programming is set. Short circuit on lights.
I suggest change battery and reset timer, then reprogram timer.
Write out schedule beforehand to avoid conflicts and overlaps.
Program 1 is ON and program 2 is OFF. Program 3 is ON and program 4 is OFF. etc.
Open following link for re-set and programming illustrations, plus battery replacement and wiring diagrams:
Sep 10, 2011 | Intermatic Inc. ST01C Digital In-Wall...
My timer is set on auto-from dusk to dawn. Comes on every night but does not turn off in the morning. This is the 3rd one we have tried and all do the same thing. Had electrician install, so think its...
You posted under Intermatic ST01C battery operated timer.
Battery operated timers cannot be exposed to freezing temperatures.
Answer below fits ST01C timer, and other similar timers.
If timer worked at one time, then timer is installed correctly. This is true for all timers.
Most in-wall timers have 1 year limited warranty.
ST01C uses CR2 battery that needs to be replaced periodically.
ST01C manual says to reset timer as last-step troubleshoot.
Programming must be entered again afterwards.
Open following link for ez programming steps and battery info.
If you are having a problem, then buy Utilitec LW60419-0192773 at Lowes.
You can install yourself using information on following link:
Utilitec does not have battery and can be exposed to cold.
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Another dawn-dusk Timer is Honeywell Aube T1033
http://waterheatertimer.org/Aube-timers.html
Aube is also battery operated like ST01C and it cannot be exposed to freezing temperatures.
Sylvania SA170 offers ez-set zip code feature for dawn-dusk operation.
Sylvania does not have a battery
http://waterheatertimer.org/Sylvania-timers-and-manuals.html#SA170
Upvote the help.
And take advantage of fixya expert assistance live.
May 22, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I forgot how to set my lamp to turn on at 4PM and turn off at 12 midnight.
You posted under Intermatic ST01C battery-operated in-wall timer.
This is not a plug-in timer.
You say you have a timer for controlling a lamp >> that sounds like a plug-in timer and not an in-wall timer.
If this is not your timer, or you are uncertain about which timer you have, then add a comment and describe your timer in detail including buttons and anything you can remember about setting times.
If you have the ST01C timer, instructions are lengthy and best done with accompanying images:
See instructions with images:
If ST01C was programmed correctly in the past, and the timer stopped working, then battery might need replacement, or timer might be bad. If battery is dead, your programs are still saved inside timer, and all you do is reset current time.
If you do not have ST01C, the following page will help identify your timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment and I will help for free.
Fixya also offers phone support for a fee, and that person can walk you through the steps. You must identify timer for that specialist to help, since each timer is programmed differently.
Dec 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I am an electrician and my client wants me to reprogram the digital timer (Intermatic) I don't know the model # but it looks like the one on the previous page. Probably the most popular digital wall timer...
Below are links to digital timers to help identify your timer.
Manuals for each timer appear on page.
Programming takes patience, which might be why your customer wants you to do it.
And these 1-year warranty timers go bad, and then timer will not reprogram, which may be another reason why customer wants you to do it.
Intermatic EJ500 and ST01C are battery operated, and will not program if battery is low.
Aube has rechargeable battery that is not replaceable, and this timer will not program if battery is bad.
Other timers shown below have clocks that operate on 120V circuit and require white neutral before display lights up.
Generally each programming is same: You set current time. Some timers you set daylight savings time. Some timers are 7-day, and some offer dusk-to-dawn. For 7-day, you set event1 ON and then event1 OFF for up to 7 programs. You choose the days for each event to operate. Before programming, make a schedule so there are no overlaps or conflicts in programming.
With Intermatic EJ500 and ST01C, event1 is the ON event and event2 is the OFF event, up to 40 events.
Add a comment if you hit trouble spot when programming.
Also fixya offers live phone support for a price.
Intermatic EJ500 with 7-day or dusk-to-dawn
Programming remains in memory forever, so you may only have to re-enter current time.
http://waterheatertimer.org/Flipdown.html
Intermatic ST01C with 7-day or dusk-to-dawn
Intermatic EI500 7-day
http://waterheatertimer.org/Programmable.html#EI500
Aube timers are either dusk-to-dawn or 7-day
Utilitec 0192773 with 7-day and astro dusk to dawn
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Utilitec 0141224
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
GE 15071 - 15086 in-wall timers: one has daylight savings time
http://waterheatertimer.org/GE-timers-and-manuals.html
Woods 59018 in-wall
Tork SS720 in wall:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Dec 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Cant get to the off setup to program timer. the timer wont come on at the set time
The ST01C is unnecessarily difficult to program.
And the manual is confusing and unclear.
I wrote a page to help ST01C users who want specific on-off times (not dawn to dusk):
I test and work with timers each day, and I had to fool with the ST01C for an hour or more.
First thing I learned is how to clear programs and start over.
Hold down ON-OFF and press reset button with paper clip.
Next thing I learned is to set programs before setting current day and time.
That way when you have to reset and start over, you are not re-setting current day and time each time.
Set current day and time after programming timer.
Timer doesn't have to be wired into the wall to set programs.
Here's a tip:
Program1 is ON
Program2 is OFF
Program3 is ON
Program4 is OFF
The key is watching the small light bulb icon on display when programming.
When light bulb is dark, that is ON
When bulb is is light, that is OFF
add a comment if you need more help
Nov 23, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I need programming info. debala@dslextreme.com
http://waterheatertimer.org/Intermatic-st01c.pdf
Pages above are for the ST01c.
If you have another timer, there are links to different wall timers, each with manuals.
If you need specific help with programming or wiring, add a comment with the specific problem and I will help.
Nov 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Need instructions to program Intermatic Model #E140C wall switch timer.
Do you mean Intermatic E104C box-type timer? Intermatic does not make E140C
Manual says "refer to programming instructions on time switch door"
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
Manual says timer has 8 events per 24-hour day ... 4 'on' events and 4 'off' events. Normal operations, selectors are set to AUTO and RUN.
Using sketchy info from manual about programming:
Set sliders to MANUAL & TIME/SET
Press EVENT for event 1 ... set hour and minute using HOUR & MIN buttons ... this will be 'on' time
Press EVENT for event 2 ... set hour and minute ... this will be 'off' time
Set all 8 events ... 4 'on' and 4 'off'
Move sliders to AUTO & RUN for timer operation
Sep 15, 2010 | Hardware & Accessories
Intermatic Inc. ST01C Digital In-Wall Timer Logo
27 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
