Question about Invacare Pronto M51 Power Wheelchair
My husband tried to put in the two new batteries today into our Pronto 51 Sure Step and he just could not seem to get to the bad ones. How does he change the batteries:
  • 692 Answers
Judy He has to disconnect the joystick cable and then pull the seat off the post raising up the seat turning lever and twisting and pulling upward on the seat at the same time. It can be hard because the seats are heavy and can be rusted. Just keep pulling and turning at the same time Once he has the seat off he can remove the cover over the batteries and disconect the cables going to the batteries and the large connector going to the power pack. Reinstall the new batteries just like the old ones replace the cover. Put some axle grease or vaseline on the seat post reinstall the seat plug in the joystick cable and you should be good to go Hope this helps
Posted on Mar 28, 2011
Have a Invacare Pronto m51 Sure step. Trying to change batteries and the seat seems to be stuck
Turn chair on its side. get spray pb blaster on it. set chair upright and wiggle seat back and forth to loosen. It takes work but after it is apart use grease on mating parts so they do not stick together anymore.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Aug 01, 2016 | Invacare Health & Beauty
I have a pronto sure step m51 I just put new set of battery's but the joystick doesn't turn on
The joystick connector may not be securely connected to the controller connector.
The battery harness may not be properly connected.
The battery fuse in the battery harness may be blown. If so, you have to get a new one from Invacare.
Nov 01, 2014 | Health & Beauty
I am getting a flashing green light when I try to charge my batteries on the Pronto M51 what does this mean
why did you change the batteries, did you verify that it wasn't the charger in the first place, sometime the charger will appear to charge but actually isn't. put a meter on one battery then plug in charger if voltage goes up charger is good if not look for loose connections and or bad charger.
Sep 25, 2012 | Invacare Pronto M51 Power Wheelchair
I have an electrlux pront stick vacume which no longer hlds a charge Is it true that there is a recall of the battery can I get a new battery since my husband the enginneer has diagnosed the problem as the...
Hmm..aug 02 2010...you probably resolved this..if not...http://www.cpsc.gov/cpscpub/prerel/prhtml09/09169.html also check the out put of the transformer...it should put out 15 volts...NOT 23 volts like mine. Saw the transformer on e-bay...http://cgi.ebay.com/NEW-15V-200mA-0-2A-AC-DC-Power-ac-adapter-Power-supply-/290372975461?pt=LH_DefaultDomain_0&hash=item439b93fb65
Aug 02, 2010 | Electrolux EL1000A2 Pronto Bagless Stick...
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
2002 PT cruiser trying to start with no keys!
I would check your wire harness. The starter is close to where you would be working on the radiator. I have not had the pleasure to put one in but i know its a tight squeez in there.
Jul 22, 2009 | 2002 Chrysler PT Cruiser
How do I charge My Pronto M51 motorized wheelchair?
Margie,   Yes you may charge it overnight. If you use it everyday,charge it every night. Once the charger senses 24 volts it stops sending a charge,so they cannot be overcharged.  I suggest when you go to bed put on the charger and unplug it when you get up in the morning.
Mar 28, 2009 | Invacare Supply Group Invacare Pronto M51...
Invacare Pronto M51 Power Wheelchair Logo
108 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
