Question about HP Office Equipment & Supplies
#56 Ink crtridge holder broke can they be replaced and were can i FIND IT.?. HP MODEL2210 MY2C2F435X ERNIE
    President:
  • 1,335 Answers
Check with one of the parts centers on the list at
http://h20141.www2.hp.com/Hpparts/Part_Resellers.aspx?mscssid=33D8D8D46E314CF09C63A2F268B98E5B&geo_code=NA
The print mechanism part number is C8654-69001.
The other thing is to check with local printer repair service centers in your area to see if they have a used printer so you can scavenge the part.
Let me know if you have any other questions.
Posted on Mar 27, 2011
Ink name
Heres the link that lets you know the compatible ink for this printer
Supplies for your Officejet 6110
Cartridges, paper, support and specs for your product
http://www.shopping.hp.com/webapp/shopping/supplies_model.do?product_code=Q1638A&aoid=5504&lang=en&cc=us
HP 56/57 Black/Color Combo
Hope I help you a bit
Mar 28, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Tip
HP Cartridge Error
  1. Try cleaning the contact point of both the cartridge and the printer's cartridge holder. Use pencil eraser to clean and make it shiny.
  2. Clogged problems can be solved by cleaning the head with water or cleaning fluids, then use an ink sanction device to remove remaining debris.
  3. HP like 56 and 57 has resetting procedures, searched it through the internet.
  4. Do not leave the print cartridges outside the printer for longer than30 minutes. If a cartridge is left outside of the printer for too long,the ink will dry out and the cartridge will become unusable.
on Jul 11, 2010 | Office Equipment & Supplies
Ink catridge error after replacing my ink catrigdes
you need hp 22 and not hp 57
you can still refill the old one
check here how
Jul 14, 2010 | HP Officejet 5610 All-In-One InkJet...
A SMALL PIECE OF PLASTIC BROKE OFF THE INK CARTRIDGE HOLDER AND I KEEP GETTING AN ERROR READING TO REMOVE AND CHECK CARTRIDGE N RIGHT. I TRIED TO GLUE IT, BUT IT DID NOT CORRECT THE PROBLEM. Is the print...
You can check in the near by store if any body can replace the catridge holder
Or else the best option will be call up HP 1-800-474-6836
And return the damage and upgrade with another printer
Do not mention about the damage simply tell that you want to upgrade your printer .
Regards Soumajit
Mar 12, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
I need the right, black #56, plastic holder,,,mine broke
25 posts - 15 authors - Last post: 12 Jul 2008I also noticed that on the new cup holder, this plastic roller has ... search first... mine just broke today. wtf. it's stuck in the down, ... i only need one cup holder.. i suppose i'll replace it later if i ... of the old cup holder still in the cup holder well, a black plastic roller bearing. ...
www.mbworld.org
Dec 04, 2009 | HP PSC 2210 All-In-One InkJet Printer
Ink cartridge 56 and 58
the printer itself recognizes cartridges
hp 57 print cartridge
hp 58 photo inkjet cartridge
and hp 28 inkjet print cartridge
any other cartridges will be of no use for this specific printer
Oct 31, 2009 | HP DeskJet 5550 InkJet Printer
HP7660 Photosmart Printer
It comes with HP #57 (C6657 A)—Tri-color print cartridge and HP #56 (C6656A)—Black print cartridge and the 56 must always be in there (the black one) but acceptable replacements for the color one are as follows: HP #58 (C6658A)—Photo print cartridge I suggest for the best photos use 58 and 56.
Feb 28, 2009 | HP PhotoSmart 7660 InkJet Printer
Which HP printers use #56 & 57 cartridges ?
Fits Models: Deskjet 450cbi ... 1350 PSC ( 57 56 HP C6657AN Ph C6656AN 57 56 HP C6657AN Ph C6656AN 57 56 HP ....
Hope this helps. Bud
Jan 09, 2009 | HP DeskJet 5150 InkJet Printer
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
