Question about Invicta Speedway 9223 Watch for Men
How can i remove links from my invicta speedway 9223
5 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: how to remove links on invicta russian diver watch
Hi Pate the only thing i can advice you is go to a service center near to your place.All watch technician like me have the knowledge to remove the links with no impaired damage or scratch.We know how to detach the links.So if want to know more of your watch i will give you a site that can help you and ask more information about your watch. www.invictawatch.com
Posted on Jun 17, 2008
indays
  • 111 Answers
SOURCE: Invicta Gran Speedway CG second Hand reset
good after noon ! the hand of your watch is need to aline , so you need to go to the watc repairman,thank you! god bless !
Posted on Sep 03, 2008
escapement
  • 2334 Answers
SOURCE: Invicta Speedway 9223 not keeping time
It sounds to me as it is a quartz chronograph and it is right that the centre seconds hand moves only if the pushbutton is pressed. If you look close enough, you will notice that the small subdial finger is ticking and counting seconds. It is recommended to replace battery, as sometimes watches been laying in stores for a few years before selling and the battery is flat or underpowered.
Want to know more about your watch? Go to www.invictawatches.com and find out.
Regards
Arthur
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: Invicta 2875 wrist watch band too large
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
Hi there, I have recenlty purchased the Invicta 9223, however, I cant get the second hand to swoop. Is there any chance you may know why please? I have read the manual inside and out... Thank...
If you have pressed the 2:00 push button, and the chronograph hand has not started, the movement is defective.
You should return the timepiece directly to the seller in exchange for another. If they are an authorized dealer, you may return it directly to Invicta with your warranty, and they will provide the repair / replacement directly.
Again, there is nothing that you are doing wrong, the movement itself is defective. We see this in a small percentage of watches, but often enough. Do not take no for an answer from the seller if you have just purchased this defective item, especially if they are not an authorized reseller / dealer of this brand.
Feb 23, 2011 | Invicta Speedway 9223 Wrist Watch
My invicta stainless steel band has two bent pins and I was told to send back to invicta repair. Is the repair of watch band more expensive than a new watch band and who can put on new band.
Most watch pins go for an average of 5 to 10 dollars per pin. If the band is in good condition there is no need to replace it. Most invicta metal bands can retail from 35 dollars and up. We are located in the Holyoke Mall in Holyoke MA
Apr 08, 2009 | Invicta Speedway 9223 Wrist Watch
Regards
Arthur
Dec 16, 2008 | Invicta Speedway 9223 Wrist Watch
I have an Invicta 5103 mechanical wind chrono and the large second hand will not zero out on the 12
To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it.
Dec 02, 2008 | Invicta Dive/Sport - SPEEDWAY CHRONOGRAPH...
Sep 03, 2008 | Invicta Speedway Collection Grand...
Invicta Speedway 9223 Watch for Men Logo
104 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you an Invicta Watch Expert? Answer questions, earn points and help others
