Question about Refrigerators
My sub zero model 642 leaks water from the bottom. when you take out the crisper drawers the coil looking tube behind there is full of water. I can't remove the tube to "blow it out" or to try to empty it out. The tube doesn't have screws or any clamps that can be removed so as to pull it away from the back wall. I've tried to take q-tip kind of thing to "absorb" as much water as possible, but not very effective. any thoughts?
    Scholar:
  • 116 Answers
Yes try boiling water and if you have a 1/4" plastic tubing like what they use on icemakers and boil some water in a pan and then siphon the water into the drain and try to push the tubing down inside the drain as your doing it to unclog/unfreeze anything in there. The tubing will get hot while your doing this you'll need a towel to wrap the tubing so you dont get burnt. Its either frozen or clogged, more than likely clogged on this model i believe. Let me konw if you need further assistance.
Sean
Posted on Mar 27, 2011
  • kathy391 Mar 27, 2011
    i'll have to go to hardware store tomorrow to purchase 1/4" tube. i'll let you know if it works. it also says "vacuum condenser". The "loovered vent thing" is above the doors. I unscrewed the piece and tilted it out and vacuumed but blinking light still on. Are they talking about something behind the fridge, so i have to pull it out from the wall and vacuum behind it ?
  • Sean Miller Mar 27, 2011
    How old is the unit, This sounds like you have a bad thermostat, and its stuck on, causing it to freeze the drain tube which is causing your current problem, the blinking light is because the unit is running too long because of the stuck thermostat, this should disappear with replacement of thermostat.
    Sean
Where is the water tank located model # frs26h7csb1
Best I can see the water tank in located behind the crisper drawers in the refer section. Remove bot bottom drawers and you will see 25 feet of 5/16 tubing coiled and tied to the back wall, that is the water tank. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 22, 2014 | Frigidaire Refrigerators
Refrigerator sub zero 736 TC water leaking under vegetable drawer
Usually from plugged evaporator drain tube.
remove all the drawers and unscrew the frame that holds the drawers. Free the the drain tube (need to unscrew the clamps that hold the tube to the back wall). Pull it up from the bottom hole where it drains into the pan and free it from the top drain pan. Most likely it\'s plugged with crap and fungus and yecchy stuff. Clean it out and reinstall it.
Jul 09, 2014 | Sub-Zero 650 / O Bottom Freezer...
I have the subzero 632 side by side and there is water dripping from under the bottom drawers onto the bottom of frig and then onto floor. Could that be the rubber gasket stripping on the bottom of the...
Behind the crispers and the shelves at the bottom is a drain trough. This drain trough is clogged and would need to be cleared by air pressure. You can use canned air you can seal the opening to keep the pressure in the tube. Once cleared you should be fine.
This happens when food or foreign object get into this trough clog or slow water flow out of the fridge section.
I hope this helps.
Oct 05, 2013 | Sub-Zero Overlay Design 632/O Side-By-Side...
Although my sub zero 642 is holding the temperature, there is water leaking from underneath the refrigerator every day onto the floor. Sometimes it is heavier than others.
it's condensate from the evaporator coils. when the humidity collects on the coils, it should drain into a pan under the fridge that gets evaporated from the hot-side line. check to see if the condensate tube from the coils is still in the pan.
Jul 29, 2009 | Sub-Zero 642
Sub Zero 642 side by side stainless steel leaks water from right door. evaporator pan is dry, water/ice dispenser door catch basin is dry. Several times per day water collects right under the stainless...
remove the crisper drawers and you will see a drain trough and a drain line . One or both is most likely blocked. If you pull the drain line off the trough usually you can clear it with a turkey baster filled with hot water
Jul 01, 2009 | Sub-Zero 642
Refrige is 48 and freezer is 0 model 532
Fixing Freon Leak by replacing evaporator coil on Sub Zero refrigerator
May 19, 2009 | Sub-Zero 642
Sub Zero 632 leaking water
Had the same problem on the same model (632). Turned out to be a plugged drain tube on the condensate collection trough located on back wall of the refrigerator. Simply pull out the crisper drawer (the drawer below the lowest shelf) and you'll bee the trough. The drip tube can easily be plugged by a vegetable leak or grape, etc which had fallen into this trough. Hope its as simple for you as for us.
Sep 30, 2008 | Sub-Zero 632 / S
Sub-Z 550 reidge internal leak
The tube behind the crisper drawers is not insulated well enough and will repeatedly freeze, leaving the water to drain on your floor. The solution is to thaw the tube and put a piece of copper the length of your tube, into the area below. The wire extending into the area below is just warm enough to keep the tube from freezing.
Aug 19, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
