Question about Dell E773C 17" CRT Monitor
My menu selection screen will automatically pop up on my screen and stay there even though I press the exit key. It will finally go away after I attempt to exit out 4-5 times.
2 Suggested Answers
  • 732 Answers
SOURCE: brightness/contrast pop up,options toggling randomly can't select
sugars_30, You or electronics technician will need to (most likely) fix the units "switch-mode-power-supply" !!! Do some extensive reading in my fixya profile and follow the links to other "cold-cathode-fluorescent-lamp" back-lit lcd monitor tech's here on fixya. They and I already have written tons of stuff that will help you to understand the problem you have. When "strange stuff" starts happening with a ccfl lcd display, the first place to look is at the innerds of the monitor. Just do some reading!!! 12fixlouie
Posted on Apr 16, 2010
How can i change the language on my mx 320
Press menu until you get to "Device settings" Press arrow right key until you get to "Device User Settings". Press "OK" Press arrow right key about 5 times until you get "language Selection" Press "OK" now press right arrow key for your desired language and finally press "OK". Use the back key to finally exit.
Jun 05, 2011 | Office Equipment & Supplies
I purchased my Norcent computer monitor four years ago. Now, the sub-menu Contrast/Brightness selection keeps popping up on my screen. So, I have to either push the #1 button to Exit or the #2 Adjust...
It seems to be a hardware issue with the buttons. They are stuck or the rubber cushion under the button has gone bad. That's the reason they are getting pressed automatically. You may take to a local store for a small repair.
Regards,
Shrey
Jun 04, 2011 | Norcent Technologies LM-965W 19" LCD...
My lap top turns on but the screen stays blank. its on but nothing shows not even a start menu
Restart your computer.
When it reloads, look for the F commands at the bottom.
You'll have to read this quick as it does not stay long.
Once you have noted which commands are available, restart again, and as soon as you see them, push the button (start before this screen appears).
This will bring you into the setup (system config) and from there you will press F9 then select "set default settings). Move to the right through each menu and do this procedure (pressing F9). When you get to exit, press F9, select "set default settings) then, press the down arrow key, and select "exit and save settings".
The computer will automatically restart. If your screen still does not present the OS (can't see anything), press Ctrl. Alt. F11.
If this does not work, open your cd drive, insert the os disc, and restart the computer. When the disc starts, you should be brought to the opttion of re-installing or "repairing" the OS.
You want to repair. This should help you fix your monitor issue.
Please let me know if you need any further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
May 17, 2010 | Computers & Internet
How do i alter the sound when i send a text message
From the stand by screen press the "Menu" key.
Scroll to Settings and select by pressing the right soft key.
Scroll to Audio and select by pressing the right soft key.
The phone will display the current ringing profile or style.
Highlight the detail option and select Change by pressing the right soft key.
Highlight "Calls" and select Change by pressing the right soft key.
Scroll through all options and select the desired Ringtone or vibration setting.
Press the end call key to exit.
Deleting a Ringtone:
Press the Menu key.
Scroll to "My MEdia"press Select.
Scroll to "Sounds" press Select.
Highlight the Ringtone to be deleted.
Press the Menu key.
Scroll to and select Mark.
Press the Menu Key.
Scroll to Delete Marked Files press Select.
A pop up message appears "Delete from phone?"
Select Yes.
Nov 07, 2009 | Cell Phones
I have starview but doesn work could someone help me here please?
Press menu/factory settings enter 0000 as password OK. select language/installation select network (< or > key)/ automatic scan. This will take about 10 mins wait for saving and exit to blank screen and press menu again. Enter 1570 on remote and scroll down to key EMU and turn on (< & > keys again). Exit out and select Sky Sports1 wait for update. When channel comes on all channels are availabe. You will need to redo favourites. If you need help on that then add comment to this psot.
Oct 05, 2009 | StarTech.com StarView SV211K 2-port KVM...
Samsung LE32R7 will not retune since switchover
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LE32R7 in DTV mode stays on BBC1
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again.
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Can't get the Guide Plus screen to go away
Try these options
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
May 16, 2008 | RCA F27649 27" TV
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Dell E773C 17" CRT Monitor Logo
Alun Cox
