Question about Watches
How to remove the back of the watch? - Watches
    Sergeant:
  • 192 Answers
Usually you will notice a small notch near the bottom, but could be anywhere.
Use something slim to pop it off.
Posted on Mar 27, 2011
Battery for relic wet or 15478 and how to remove back of watch
Watch back will almost certainly need a dedicated wrench to loosen and unscrew it. Sometimes considerable force is needed and in that case a watch repairer would remove the strap and fit the watch into a bench-mounted holder.
Once the back has been disturbed the water resistance cannot be guaranteed unless it is pressure tested after refitting.
Jan 23, 2017 | Relic Watches
No slot or screw to remove watch back
Check the top around the crystal. Some of those watches came apart from the top of the watch. Generally a few screws to remove. If no screws then the back pops off. Not easy but it may be the way in.
Again, if it's a decent piece go to a jeweler to do the work. Should be under $10.00. to do it.
thank you, gabe.
Oct 22, 2015 | Watches
Change the battery
You need to remove the back of the watch to get to the battery. If the watch is a water proof watch then the back is screwed on. After removing the back take care not to damage the gasket.
If you cannot remove the back of the watch then take it to a watch repairer, they can replace the battery and it won't be expensive.
Mar 09, 2013 | Watches
I can't remove back of "my wish" watch.
Maybe he can't, doesn't mean it can't come off. Find a more competent jeweler or watchmaker. If it is true the back can't come off then the watch comes out through the top or crystal. Did you pay $20 for the watch or $20 for shipping?
Nov 30, 2012 | Watches
Remove back cover
If the watch back has about 10 groves on it take it to a watch repairer.NO groves then a sharp knife like a small Pearing knife find the grove between watch and cover put knife in and gently prize open.
Aug 16, 2012 | Timex Expedition Watches
The word (op en) on the top in place of the date or the day and nothing is responding
I had this problem and managed to fix it. There is a small metal plate locate inside the back cover of the phone that can be knocked out of position. The small plate should be in contact with the two screws in the top right hand side of the watch (when back plate is off).
To remove back plate you must remove the strap. To do this you must remove the four pins that connect the strap to the watch body. Take out the pins and set aside. The two plastic inserts can now be removed.
Remove the four screws and remove the back plate. Be careful not to lose screws, rubber seal and small plate.
Reglue the small plate to back plate and allow to set.
Reassemble watch in reverse order and watch should work as normal.
Good luck
Feb 27, 2011 | Casio Protrek Triple Sensor PRG70 1BVDR...
I have a pocket watch i bought in paris but the battery ranout and i cant get the back off to get the battery out. what should i do?
Hi Josh, I do apologize for the inconvenience.Please try the below steps which should be helpful for you to remove the back of the watch and also replace the battery.
  1. Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
    (OR)
    Find the small groove on the back of the watch right above the hinge,place the tip of the screwdriver (the small kind used for the screws in glasses) into the groove and gently pry off the back of the watch.
  2. Remove the circular watch battery out of the back of the watch.
  3. Take the battery to any department store or watch store and purchase a new replacement battery.
  4. Insert the new battery into the back of the watch.
  5. Screw on or push on the back of the watch. Set the watch to the correct time.
The above should be of help for you to have the battery on the pocket watch replaced and have the watch working once again.Best wishes for your effort and thank you for your time and patience.
Nov 12, 2010 | Fossil VT2654 Pocketwatch
Cannot open watch-back says, ''bezel stainless steel back''
Take it to your local jewelry store, they will sell you a battery and install it for you. Watch how they do it for the next time.
May 17, 2017 | Watches
How do you remove the back of a Fossil watch to change the battery?
good morning ! to remove the case back of your fossil watch,just snap the case back use the knife to do that ! but if your fossil watch is waterfroof design you need to use the wrench opener for treaded watch case back ! good luck ! god bless !...
Sep 02, 2008 | Fossil Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
