Question about Refrigerators
Electrolux RM 4270 caravan fridge
My fridge has stopped working and i can't find out how to remove it from my Bailey Ranger 470/4 caravan
Can you help please?
Thankyou for your assistance, but i found the solution with electrolux direct.
Hope to use your site again sometime.
Posted on Aug 05, 2008
Bailey caravan problems
How many caravanners out there has had problems with the cpi pn the Bailey GT65
Jan 01, 2014 | Computers & Internet
I NEED A USER MANUAL FOR ELECTROLUX GAS FRIDGE IN MOTOR HOME. MODEL IS RM 2260 AND PRODUCT NO. IS 9215430-01. GAS IGNITION SYSTEM NOT WORKING - THANKS FOR ANY HELP JAMES GREIG SMITH
Hello, here is the manual: -
http://web.me.com/danperkinsartwork/Autohomes-Bedouin/Manuals_files/Electrolux%20RM2260%20operating%20and%20instalation%20instructions.pdf
Also found this site with a list of parts for the fridge you mentioned
http://www.leisureshopdirect.com/Caravan/ventilation/Dometic_Caravan_Fridge_Spares/Dometic_RM2260_Fridge_Spare_Parts.aspx
Hope this helps, good luck
Aug 04, 2011 | Electrolux Refrigerators
What does a CE error code on an Electrolux refrigerator (model EW26SS65GS) mean?
My fridge was having the same problem with CE being displayed, light and touch selector not working. With the assistance of one of my sons, we tilted the fridge back slightly and removed the control circuit board. Two of the three 470 u F capacitors were toast. My son drilled out the plastic brads holding the circuit board in the pan, then removed all three of the 470 u F capacitors. He soldered 3 new capacitors in place (0.59 cents each) and used 4 small screws/nuts to secure the board in place. After looking at the capacitors, he said a power surge had caused the damage. We went right out and bought a surge protector for the fridge. My fridge works perfectly now. While protecting tvs and computer from surges, I had never even thought of using a surge protector for the more costly fridge! Hope this helps someone else avoid an shamefully expensive parts replacement.
May 09, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
I have a 2453 150 litre caravan fridge not working on 240 but works on gas. What maybe the problem and can i get a mobile repairer
It sounds like the electric heater is not working as you say it works on gas, so the expensive bit is OK.
An appliance engineer should be able to get the spares and fix it.
Mar 07, 2011 | Microwave Ovens
We have 3 way fridge RM 4203 601 model , it want
http://www.obrienscamping.co.uk/discontinued/RM4200.htm
This will help, but are you sure you hane 220Volts at that plug, on its own circuit. Did yoy check the breakers, some times you have to push them all the way off, then push on, to reset the breaker.
Jul 04, 2010 | Electrolux Refrigerators
Electrolux fridge in my caravan will run on gas,
Hi it sounds time to pull it out and give the ignition box a good blow out to remove dust and cobwebs. Also remove the jet in the supply pipe where it screws on to burner box. Just wash and clean it dont poke anything in the jet hole. Graham
May 13, 2010 | Refrigerators
Our caravan fridge electrolux rm4206 gets cold on both gas and 240v mains but does not seem cold enough ie freezer compartment is not quite frozen and fridge compartment is not cold enough. Any...
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Aug 27, 2008 | Electrolux Refrigerators
We have caravan electrolux rm 4230 light is on for 240 chilling, but fridge does not cool. appliance does however cool fine on gas.
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.
http://www.leisureshopdirect.com/caravan/ventilation/Dometic-Electrolux_Spares$$6.aspx
Jul 05, 2008 | Electrolux Refrigerators
Refrigerators Logo
1,313 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
