Epson rx 680 error message changing cartridge
  • 2,574 Answers
If you have just installed a new cartridge and you still see an ink related error, the cartridge may be incorrectly installed.
Follow these steps to make sure the cartridges are correctly installed:
Make sure the Epson Stylus is turned on.
Make sure the CD/DVD tray is not inserted and the CD/DVD guide is in the paper printing position.
Do one of the following:
If your printer indicates that an ink cartridge is expended, press OK.
If your printer does not indicate that any ink cartridge is expended, press Setup, select Maintenace, and press OK. Then select Change Ink Cartridge and press OK.
Open the scanner.
Open the cartridge cover.
Note:Never attempt to open the cartridge cover while the print head is moving; wait until the cartridges have moved to the replacement position.
To avoid damaging the Epson Stylus, never move the print head by hand.
Press down all the ink cartridges until they click into place to make sure they are properly seated.
Note:If a cartridge is properly seated already, you may not hear a click.
Close the cartridge cover and push it down until it clicks into place.
Close the scanner.
Press OK to begin charging the ink. This takes about 1.5 minutes.
You see a message on the display screen when ink charging is finished.
Note:Never turn off the Epson Stylus while the ink is charging or you'll waste ink.
Posted on Mar 27, 2011
Printing problem
Did you use Epson Genuine Cartridges? ???
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 08, 2010 | Epson Stylus RX680 Color All-in-One InkJet...
My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
Not printing green light flashing red one constant
Here is the indicator light error page from the Service Manual
You will see there is no specific error of "Power flashing" with "Error On". The inference is that the Power light was doing someting to cause it to flash (e.g. jn cartridge change mode) when something went wrong to cause the "power no change" with "red light on" error. The most likely I think is "no cartridge" - or more likely "faulty cartridge looking like no cartridge". Have you tried re-replacing the cartridge with yet another. Other possibilities are some sort of mechanical jam. Please report back on this.
Dec 17, 2008 | Epson Stylus 680 InkJet Color Printer
Loading the ink cartridges
did you take out the sticker of the cartridge?
Nov 13, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
Epson CX 5400 won't recognize off brand magenta cartridge
Yes replace the possibly faulty cartridge as some just don't work. If you take it back to where you bought it from they may replace it with annother one free of charge?
Hope this helps....
Nov 03, 2008 | Epson Stylus 680 InkJet Color Printer
Epson Rx680 Photo all in one
Call Epson again and complain. This is a known defect on new machines shipped. I had the same problem and they sent me a new printer under warranty (same model) without any issues. The new one works perfectly.
Oct 15, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
RX 560
either a faulty ink cartridge chip or an old chip (epson did some magic earlier in the year)
try original cartridges to prove problem
Aug 05, 2008 | Epson Printer
Epson CX5400
Nothing wrong with the printer. The rubbish cartridge you bought and replace it with one that works. Approx 30% of most compatible/refilled cartridges DO NOT WORK.
Not only that but they WILL block your print head nozzles eventually. Ever wonder why Epson do NOT make any flushing cartridges but almost every compatible "maker" does??
99% sure the cart is at fault. return it to where you bought it and get a swap.
Jan 04, 2008 | Epson Stylus 680 InkJet Color Printer
26 people viewed this question
k24674
jasbo
jasbo
