Question about Freezers
Upright freezer defrost it, and for 2 to 3 weeks works fine, then everything is covered with snow crystals, and bags are full of ice. Freezer would be about 10 years old.
    President:
  • 1,779 Answers
Sounds like your freezer isn't maintaining a constant (cold) temp. A variation from cold to warm would cause your problems. Normal opening the door and looking for the ice cream over and over would cause a gradual increase in glacier activity in the freezer. I don't know of any quick easy fix-but wait, how about checking the door gasket? Get a piece of paper, close the door on it, move the paper all around the door, testing to see if you can pull it out easily (bad gasket), or does the paper not want to come out?(good gasket) If the gasket seems ok, it may be time to retire the global ice cream warming freezer countrycurt0
Posted on Aug 07, 2008
When I got home I heard the buzzer going off on the freezer..the temperature had dropped from -12 to -2 and I'm trying to reset it to-12 again how do you do that?
You dont have to reset it, you need to defrost it, the defrost element has failed and you have ice build up within the chiller plates, air cant pass through it due to the ice, I think you will find that food is starting to defrost and you will see a bit of ice on the back panel inside the freezer.
Defrost it for 2 days with door open, after that, should work fine for a week or so, very common problem.
Hope that helps, Russ
Jun 29, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice under the cover
You can use a hairdryer to speed it up but you need to fix the defrost sytem.
How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 20, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Woods upright freezer
I would look at the defrost control [sometimes they are defrost clocks]Maybe that the freezer is not defrosting.
Jun 26, 2009 | Freezers
My Whirlpool upright freezer keeps building up ice inside the bottom back wall. The fan starts rattling and freezer will not stay cold enough to make ice. If I take everything all out and leave it off...
Either your defrost timer, defrost heater or defrost thermostat has failed. All parts are located behind the lower back panel inside the freezer. Most likely are the defrost heater and defrost thermostat.
Jun 09, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Freezer freezing up
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost themostate, heaters, or timmmer
Sep 16, 2007 | Freezers
Freezers Logo
179 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
