Question about Amana Kitchen Ranges
I cancelled the clean proprocess and then the display shows 5ab and I can't get the oven to work or clock .. anything, no beeping
  • Amana Master
  • 2,694 Answers
Somehow you put it in sabbath mode,yes sabbath mode,a feature known as "Sabbath mode." According to the Jewish Sabbath law, raw food may not be cooked on the Sabbath, but food that was already cooked beforehand may be kept warm until mealtime. On Jewish holidays, food may be cooked fresh, but turning the flame on poses a problem given electrical requirements forbidden by Sabbath observers.try holding the clck button in for 3 to 5 seconds to take it out of sabbath mode
Posted on Mar 27, 2011
  • Sal De Mar 28, 2011
    how did you make out,if that didn't help look in your manual and it will tell you how to take it out,also you can go to this site,put in your model number and copy the manual from the site,good luck......managemylife.com
The electronic panel related to oven and clock does not work. code 5ab appears on the display
Hello, welcome to FixYa.
Your range has somehow been set in "sabbath" mode ( for the Jewish calendar I think...not the metal band, lol ) If you have the owners manual turn to the section referring to this an it should instruct how to reverse the setting.
All ranges do it somewhat differently, so I can't say exactly how on yours. This example is generic, hopefully it works. If you are unsuccessful let me know the exact model number and I'll see if I can locate it.
Hold Clock pad for 5 seconds to activate Sabbath mode. Hold Clock pad for 5 seconds to disable Sabbath mode.
Oven must be in BAKE mode before enabling SABBATH. "SAb" displays and flashes for 5 seconds. All pad inputs are disabled except for CANCEL and CLOCK pads.
This mode disables the normal 12 hour shutoff to allow operation of the bake mode for a maximum of 72 hours.
Good luck. Thank you for choosing FixYa.
Regards,
Macmarkus :)
Jul 18, 2011 | Maytag Gemini 30" Self-Cleaning...
Tip
My oven displays error code 5AB
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
on Mar 05, 2010 | Ovens
My power went off today and when it came back on, my Kenmore oven shows error code "PF 5 AB". None of the buttons work that I press. Burners turn on, but can't turn on oven. Suggestions?
Could that be PF power failure 5AB in the Sabbath mode. That's a new one.
Your model number is useless. Sears has a big 3 digit product code followed by 8 digits.
But let me dig up my 5AB notes:
Here is what I have:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Hope this helps
Mar 19, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
The code shows 5ab and the oven will not work
The range has entered the Sabbath mode.
Press and hold the clock button for 5 seconds to cancel the Sab mode.
Mar 02, 2011 | Maytag MERH752CA (Electric) Kitchen Range
Readout is stuck on 5Ab. Can't do anything with it
Hi.
Regards.
Jul 09, 2009 | Maytag MEW6530D Electric Single Oven
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
My gas range display changed to "5Ab" and does not work anymore.
You are set to Sabbath mode.
Try holding the clock button in for 5 seconds and that may correct it.
Mar 10, 2009 | Amana RanARG7302 Gas Kitchen Range
Error code 5A6 on Maytag oven MER5755QAB
My range showed a code of 5A6, I held the clock key down for a few seconds and it corrected itself.
Sep 28, 2007 | Maytag MER5775Q Electric Kitchen Range
Oven and clock inop
You might have a problem with the circuit breaker - reset it by pressing the switch ocated on he lower edge of the backguard (in Canadian models). There are several things that could cause the oven not to operate, but generally you would get a message on the display - "Lock", "Sabbath" etc. Just in case your display is damaged and that's why you don't see any message, try to press and hold the "cancel" and "cook and hold" pads for three seconds (to unlock the oven in case it is locked), and then check to see if the oven works. if not, repeat this procedure (to make sure that you didn't lock it just now), and then press and hold the "clock" pad for three seconds (to unlock the oven in case it is in "sabbath mode"). If it still doesn't work, you might need to replace a fuse.
Apr 05, 2006 | Amana AER5515QA Electric Kitchen Range
Kitchen Ranges Logo
552 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
