Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
DISHWASHER LEAKS OUT BOTTOM OF DOOR - Frigidaire 24 in. FDB1050RE Built-in Dishwasher
    Master:
  • 414 Answers
Look to see if the small plastic corner diverters are missing or out of place, this
will cause this to happen. They are located near the door on the bottom of the tub
and are about an inch long made of semi translucent plastic. They often come out easily.
I hope this helps.
Posted on Mar 27, 2011
SOURCE: dishwasher leaking around the bottom of the door
We just had the very same problem and sure enough a flexible cutting board was over the outlet...very strange but thanks
Posted on Mar 12, 2008
  • 338 Answers
SOURCE: Dishwasher door leak
at the bottom of the door is going to be the door seal starting to go bad. replace the seal
Posted on Dec 01, 2008
futureloginn
  • 734 Answers
SOURCE: fidgedaire dishwasher leaking from bottom of door
You can try and make the door close tighter. Open the door, and there should be 2 screws that hold the other side of the latch. Loosen the two screws and push the latch back towards the back of the tub. Tighten and see if that takes care of the problem. That is where I usually start when leaking from the tub.
Posted on Dec 02, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore dishwasher leaking from bottom of door
This is commonly caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub. The only other items that can contribute to leaking are:
1. A dishwasher that is not level, which causes the door not to seal properly.
2. The inner door panel being warped causing the door facing not to be even for the gasket to seat properly.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being deflected over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
NOTE: Most dishwashers do not have a seal across the front lip of the tub. That's why it's important to have a good door seal and to load it properly.
If you've loaded the dishwasher properly and confirmed it is level (front to back and side to side), then here are your options:
1. Replace the inner door panel at a cost of about $115.
2. Replace the door seal at a cost of about $35-$40.
Parts can be purchased from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever parts source you like, but I have found these to be the cheapest and most reliable sites to order parts from. Shop all of them for the best price.
NOTE: The inner door panel is listed under the Door Parts section. The tub gasket will be listed under the Tub Parts section.
I think I would pursue the cheaper option, first. Its also the much simpler option. To replace the door seal, follow these steps:
1. Pull the old door seal from the groove around the wash tub facing. Take note of which surface area of the gasket is inserted in the groove and which surface is facing the door. It may not seal properly if you install the gasket the wrong way.
2. Clean the area really well to ensure there are no food debris or soap deposits. Also clean the inner door area where the door meets the gasket. You need a clean surface for the best results.
3. Locate the center mark of the new gasket. This will be a small paint spot or small groove on the gasket (this surface is the side of the gasket that will be inserted in the groove around the tub facing). If there is no center mark, fold the gasket in half and mark the location with some chalk, or hold with your fingers.
4. Locate the top center part of the wash tub facing and align the center mark of the door gasket at that point. Begin pushing the gasket into the groove with your hands and work your way around and down along each side.
5. Make sure the gasket is inserted all the way around the tub facing to the point where it meets the wash tub bottom. You can pull the gasket out and readjust as necessary.
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Sep 10, 2009
localwonder
  • 6784 Answers
SOURCE: door of dishwasher is leaking at bottom left corner.
HI. the door seal has been compromised. it could be simply farad or slightly propped open by some sort of debris as well. check the door seal for faults. replace if faults are found.
Also, make sure the door isn't mis-aligned. this will happen over time during heavy usage. re align the door if necessary.
Posted on Sep 22, 2009
Leaking at the bottom in the middle of the door
you need to determine if it's coming from inside the door or under the front of the dishwasher, if the door latch needs adjusting it can get water through the latch slot, the dispenser can work it's way loose and water can leak through it, or the seal on the bottom of the door can get dirt stuck on it which can cause water to leak out.
Otherwise it could be in the bottom of the dishwasher, it is a matter of closer investigation.
Mar 10, 2012 | GE 24 in. Profile PDW7800 Built-in...
Leaking bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
May 24, 2010 | Frigidaire PLDB998A Built-in Dishwasher
Why is water leaking from the bottom of the door? Do I need a new seal?
Hi, Yes... Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
May 20, 2010 | Amana 24 in. ADU5000D Built-in Dishwasher
Why is my dishwasher leaking from the bottom of the door? Is it a seal???
It could be the door seal,check for damage.Check how dishwasher is loaded and make sure door is closing fully.Check bottom spray arm has not split on the outer edges.Clean all filters.
Hope this helps.
May 14, 2010 | Dishwashers
Dishwasher leaking out the bottom of the front door
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaks from the bottome of the door
if it leaked everytime then it would be your door gasket.but not everytime it's your door latch not engaging completely everytime.open the door and look and see if you can access the tightening screw for the door latch.probably not but look anyway.if you can then tighten the latch.
Nov 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
470 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
