Question about Numark CD Mix2
Yes how to set up to an amp - Numark CD Mix2
    President:
  • 1,489 Answers
There are two balanced outputs from the mixer as well as two RCA outputs (right & left). The simplest connection would be to run RCA cables from the RCA mixer output to the auxiliary input on an amp.
If you want to use the balanced outputs from the mixer, you will need adapters (or cables with correct plugs) to go from balanced conectors to RCA or 1/4 " inputs on the amp.
More info, let me know.
Charlie
Posted on Mar 27, 2011
Guitar amp had high volume feedback now the sound is different
The short answer is yes. You didn't tell us what make/model/speakers, but if it was really high volume you may hsve blown a speaker. Of course, if you let it get out of hand you can damage your ears.
Mar 23, 2016 | AMP Music
Can you repair a tear in a peavey guitar amp and will it affect the sound
I have to assume you're really meaning a tear in the speaker cone. If so, yes you can repair it if it's small and yes, it will affect the sound. Peavey Bandit amps have come with a few different speakers over the life of the name, but all will still be available either online or directly from Peavey's parts department. Here's the link-
http://www.peavey.com/support/contactinfo
Oct 21, 2015 | Peavey Bandit 112 80W, 12" TransTube Combo...
Hooking up two amps together
Yes. There could be big issues depending on how you want to "hook" them together. If you are wanting to simply run them at the same time (play through both at once) you can get a cheap signal splitter from GC or Radioshack and run your bass to the input, then output 1 and 2 to the respective amps. That is your best bet.
Setting up two amps parrallel does not nessesarily add power. That is to say that your 150 and your 350 "hooked" together does not give you 500 watts. In addition, there may be some issues with running a powered signal from the first amp into an input that is not designed for powered signals. Try the splitter or an old fashioned AB box. Safe and a cool trick. You can also use a stereo chorus pedal and let the signal chorus between amps. Makes the bass sound huge! Try it and good luck.
Jun 17, 2013 | Fender Music
Line 6 how do i get it to work
Line 6 connected to AC power and LED showing power to unit. Guitar into effect input, effect output to guitar amp. Does guitar make sound through amp in bypass mode? No then check cables...yes then use foot switch to turn Line 6 effects unit on. Adjust control knobs for desired effect levels/settings.
If pedal provides no effects...off/on switch defective or internal electronics in need of repair.
Oct 26, 2012 | Line 6 DL4 Delay Modeler Effects Guitar
My line 6 spider mk 11 starts making a cracking noise about 50-60 seconds after i turn it on, then loud fuzz noise- whats wrong plz help
Disable ALL digital settings....problem gone? If not, with tube guards and/or shileds removed try lightly tapping on each tube (one at a time). Does your amp go crazy while tapping one particular tube? If yes then it is new tube time.
Oct 18, 2012 | Line 6 Spider Valve 112 MkII 40 watt 1x12...
Can i add another speaker to it
The specs do NOT show an auxilary speaker jack so the answer to your question is that you cannot add another speaker.
Mar 08, 2011 | Pyramid GA610 600 Watts Dual Channel...
CAN I PLUG IT IN TO MY AMP
Yes the output jack socket can be used either to:
  • plug in a set of headphones for personal listening / practice
  • to connect to an amplifier.
The zoom pedals use either a mono or (tip and sleeve) or stereo (tip, ring. sleeve) 1/4 inch jackplug - i.e a standard guitar lead.
You should plug it into a line-level or high impedance socket on your amp. With the pedal in play mode you can adjust the output level (gain) to match the input requirements of your amp by rotating the 'Value' knob (top right)
Feb 26, 2011 | Zoom B1 Bass Multi Effects Pedal
Are the controls on the Peavey IPR-1600 used as volume levels?
Yes, they are NOT intended to be changed for routine volume level changes, but instead for initial balancing. Ideally, you would like to have them set about 2/3 up and control level from your mixer or other device.
Jan 03, 2011 | Peavey IPR-3000 Power Amp
Can i connect the pv 112 to the pv 118 subwoofer since the powered mixer i bought it only has 2 main outputs? The powered mixer I bought is the PV XR 8600D powered mixer...
Generally speaking you should only send low frequencies to subs. The highs, while lower in power than the lows, will over time harm the voice coils. The ideal way to do this is to use an external crossover netween the main output and the amp input with the higher range going to a general set of speakers. Send the lows through the second channel of the amp and then to the subs.
In short, while not recommended, yes you can hook them up in parallel.
Dan
Dec 09, 2010 | Peavey Pv118 1x18" Subwoofer Speaker...
Can I sign four toms to my dtxpress iv? thanks Arpi
Yes you can my friend. You can even have up to four more I believe. Please read here that everything is easy to understand:
http://www.arrangerworkstation.com/forums/showflat.php?Cat=&Board=DTXpressIV&Number=441199&page=&view=&sb=&o=&fpart=1&vc=1
Take care and enjoy your DTXPRESS IV!
Nov 13, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Numark CD Mix2 Logo
105 people viewed this question
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
rhodesworks
Seanzilla
Are you a Numark Music Expert? Answer questions, earn points and help others
