Question about Creative Labs Inspire T3030 Computer Speakers
T3030 speaker system with wired remote.was using headphomes..removed them and now no sound from speakers.all lights on..no sond
  • scooby389b Mar 27, 2011
    not it ,tried another set of speakers and they work,problem with speaker system want to fix
  • Creative Labs Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 27, 2011
  • Brian Sullivan
    Brian Sullivan Mar 28, 2011
    Inspire T-series tweeter
    This dedicated driver reproduces the higher-end frequency spectrum, revealing more intimate and detailed high notes that many speakers cannot reproduce. It seamlessly complements the mid-range driver, adding just the right amount of presence to your playback, allowing you to savor a more natural and convincing audio reproduction.
    i dont have these speakers to check but it seems it has a dedicated driver maybe it has been corrupted or the remote control might not be working properly check the connections
My speakers just for some unknown reason aren't working.The remote control won't light up anymore
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
if you don't have the drivers you will need to download them
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10005159.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-sound-blaster-audigy/3000-2120_4-10198811.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
Jun 29, 2011 | Creative Labs Inspire T3030 Computer...
I use the system in my room for my i pod and one day it just stopped working. when i plug it in and try to turn it on, nothing happens and there is no green light...whats wrong?
This sounds like the power adapter for your speakers is not working.
If you have some electronics experience you can test your adapter with a multimeter or maybe have someone else do it for you.
If you plan to replace the adapter, (if it is the adapter that is not working) be sure to use the same AMP and Voltage rating that is on the original.
Nov 29, 2010 | Creative Labs Inspire T3030 Computer...
No Sound from External Speakers....only from Headset plug.
Hi, had same problem.... unscrew the remote and carefully remove the back end part of the stereo-connector (very careful !) it consists of a very small switch which moves sideways..... this switch is stuck into headphone-modus. Reassemble and it will work again
Note that speakers will work if you remove the switch
Apr 19, 2010 | Creative Labs I-Trigue L3800 Computer...
How do i set up
Ty this - there is one wire with a green end - plug this into the sound card on your pc.
Take the one wire from the left speaker and plug it into the main control box to the matching plug.
Take the remaining wire and plug it into the other matching plug on the back of the main LARGER control box.
Plug it in the wall socket.
Play music on your pc.
Mar 29, 2010 | Creative Labs Inspire T3030 Computer...
No sound from creative t3030 2.1 speakers
you checked adapter light the green light is show
Jul 23, 2009 | Creative Labs Inspire T3030 Computer...
the circuit board and amplifacation supply inside the sub are blow or shorted out.thus preventing any sound. the head phone jack works only because it is a bypass feature supported by the actual computer not the surround sound unit
Jul 23, 2009 | GE Ultrasonic 2.1 Subwoofer Computer...
Creative Inspire T3030 speakers not working
hello
I have creative inspire T3030 ,dont function ,Iwant help
Mar 31, 2009 | Creative Labs Inspire T3030 Computer...
Creative Labs Inspire  T3030 Computer Speakers Logo
212 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
