Question about Samsung HT-P38 System
I need to buy the wires of speakers to plug in
    Brigadier General:
  • 8,546 Answers
Connecting Speakers to Marantz NR1402
HI,
You can use banana plugs to connect speakers to the speaker post. Connect the wire to the banana plug then insert the banana plug in the speaker post.
If you serch in google with the name speaker banana plug then you will get picture of different types.
You can buy this banana plugs in any nearby electronic spare part shop. They all stock this item. Normally comes in pair ( red, black)
Ajin
Feb 22, 2012 | Marantz Audio Players & Recorders
My speakers aren't getting any power. I feel confident I have traced power all the way to the switch. Would anyone have a schematic diagram for Logitech x-240 speakers?
Hello little richi,
I would suggest plugging your speakers into another outlet first to be sure that your speakers are the problem. I would then suggest to check and see if you can remove the power cord, which I would assume is universal and can bought at many retailers, and install a new one.
If the switch was the problem, this situation becomes more technical. You most likely would have to buy a new plug. There are electronics retailers such as Jameco and Newark. We're not talking about places like Best Buy and Walmart here. Jameco and Newark sell plugs that you would have to solder on to the wire. The plugs should be real cheap. If you know how to solder, all you would need to do is solder the wires on to the plug.
Jul 20, 2011 | Logitech X-240 Computer Speakers
How do you replace the radio and insert a cd player?
Hi, pull the trim plate off the dash around the radio. The trim may go all around the instrument panel. With the trim plate off, you can see the factory radio screws. Take the screws out, pull the radio out and remove the connectors, including the antenna wire.
You will need an adapter to fit the aftermarket radio snugly into the dash. They sell these wherever they sell aftermarket radios. I recommend you also buy the cable adapter. If you don't, at least buy the antenna adapter of you will no be able to plug your antenna into the new CD player.
Follow the instructions on putting the adapter together--it's made for a lot of different cars. You need it to screw into your dash where the screws came out.
If you buy the wire adapter, follow the directions that come with it. I recommend you solder the wires, but you can use those crimp connectors if you don't have soldering equipment.
If you don't buy the adapter cable, use the factory wire colors below to match up the aftermarket wires to your factory wires. Wrap any solder connections with electrical tape and carefully plug everything back in, including the antenna adapter and antenna cable. With the adapter plate attached to the new player, carefully push the wiring aside to get the player into the slot and then screw it in. check the system for proper operation and then replace the trim panel.
Enjoy your CDs, and let me know if you have any questions.
2002 Chevrolet Silverado C1500 Radio Wiring Instructions
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jan 16, 2011 | 2002 Chevrolet Silverado 1500
I am looking for speakers to replace the ones that r in it.They r they original speakers that came with the car. Delco speakers-they have 1 adapter female plug on each side of the back speakers. Can't find...
any aftermarket speaker you buy will not have that style plug. you need to cut off the original connector on the wiring, and use the connector for the aftermarket speakers - there are a couple different style connectors, whoever you buy the speakers from can provide the proper connectors that you will crimp onto the wiring. good luck!
May 10, 2010 | 2000 Pontiac Grand Am GT
I NEED TO KNOW WHAT WIRE IS SPEAKER POWER FRONT
go to a good stereo shop and buy a harness adapter kit for your specific car
Oct 21, 2009 | Car Audio & Video
Need to install cd player in 97 wrangler. need to know which wires are speaker ground power etc.
easiest thing to do is to go to best buy and buy a radio harness kit for $15-20 which will plug ontop of your radio harness so you don't have to splice any wires. the kit is a plug on one end and labeed wires on the other end that will tell you where everything you need is to install a new cd player in such as your power, ground, remote, and speaker wires...much easier to do then to splice and trace each wire.
Jul 11, 2009 | Wrangler Jeep Twin Stroller
Altec Lansing speaker - model ada 745
I am guessing you mean the cord that goes into the PC, I don't know how "Broke"it is, but you should be able to cut the old end off and replace it, if you buy an inexpensive speaker extension cable, you can use that for the new end, or try radioshack, they may have replacements that just need to be wired, usually a black and red wire is all, just tape it up good to avoid shorts
Apr 30, 2009 | Altec Lansing ADA 890 Computer Speakers
Need one set of speaker wires.
If the wires have just bare ends plugged into spring-loaded contacts then you can get some twin lead from radio shack or walmart. Just make sure you match the colors from the stereo to the speakers
otherwise you might not get real stereo or surround.
Jun 02, 2008 | Sony DAV-S300 System
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
10 pin plug wiring configuration
7e83231.jpgI had the same problem.  Here is the picture I used.
Oct 05, 2007 | Kenwood KSC-WA82RC Car Subwoofer
Samsung HT-P38 System Logo
257 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
