Question about HP OfficeJet Pro K8600 Printer
Change print heads - HP OfficeJet Pro K8600 Printer
    Guru:
  • 89 Answers
Replacing Ink Cartridges and Printheads
Video on the link below will guide you how to do it
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01289505&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=3434447
I added some concerns that may help you in printhead and inks issues in the future
Aligning Printheads
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01289582&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=3434447
Checking Ink Levels
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01289598&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=3434447
Hope I help you a bit
Posted on Mar 28, 2011
How to change the pin head
I assume your asking how to change the "Print head" power off the machine, remove the ribbion and plastic mask (lifts up) you will see 2 gold phillips head screws. unscrew them both and lift up the print head. push in new print head and reverse the directions you removed.
Jul 24, 2014 | OKI MICROLINE 5521 Matrix Printer
Unable to init. 4F
4F is Main PCB Faulty unfortunately most likely from Power surge. Do you have warranty ?
Feb 25, 2014 | Brother MFC-J615W Compact Inkjet...
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
Oct 05, 2012 | Brother MFC-J220 All-in-One Color Inkjet...
How to change cartridge after ink has dried
Changing the ink cartridge is not the only problem, the print head will need to be changed as well.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 20, 2011 | HP DeskJet 3745 Printer
I am a Reseller and one of my client is having Citizen CLP-7202e. due to the faulty print head we have tried to change the print head and after changing a new print head, printer is not printing...
I have used this type of printer before. Long ago when it was called the C-ITOH. However, never had to change the print head before. I would imagine that if you did - all the adjustments would need changing. Bad Gap would skip labels and bad pressure would make them too light or too dark. If there are any vertical lines (even faint) the print head is damaged. Also, these things are very specific as to media vs ink roller. You cannot use a paper ink roller with mylar labels. Vise versa works but those rolls are more expensive. I am sure you have tested this already but you point pretty exclusively to the "new" print head with your testing. Sounds like you have answered your own question. I would do some continuity tests on the head to see if it carries any current at all. Good Luck!
Jun 14, 2011 | Citizen CLP-7202e Thermal Printer
How to replace print head in Canon PIXMA MP630?
Most cannon printers have same print head, and replacing them is relatively easy... First open up printer cover to get to the print head. If you have manual for your cannon model, see in manual how to change color cartridges. When you get print head in position for changing cartridges, take out that CMYK cartridges one by one. After that, you will notice there is some kind of a lever on one side of print head. Try to pull that lever up, and it should release your print head. Now you can take it out, and put a new one if you have it.
Mar 06, 2011 | Canon Office Equipment & Supplies
One colour, Cyan will not print.
Some nozzle on print head is clodged. Remove the head, on some cloath, spill water and few times press head nozzles on it ( bottom side ), dry it and then do the head cleaning. If dont help change print head, when print head is changed its also recomended to change absorber and purge unit too.
Jul 02, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Yelllow wont print,...changed cartage cleaned
If after cleaning the print head and changing the cartridge yellow still doesn't print, it sounds like there may be a problem with the print head or the board that controls the print head. The print head may not be receiving the signal to turn on. Check the circuit boards on the machine for obvious damage or a burn smell. Depending on the model printer it may be cheaper to replace the printer than to have the board or print head replaced.
May 15, 2010 | Epson Stylus 2200 InkJet Photo Printer
Will not print plank pages,even after cleaning.
check print head and head cable............
If ink flow change mainboard, print head, and head cable. if ink not flow change only main board
Jan 06, 2010 | Epson Stylus C84 InkJet Printer
Printer does not print magenta and cyan. Change
The print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Nov 12, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
HP OfficeJet Pro K8600 Printer Logo
327 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
