Question about Whirlpool Washing Machines
Our whirlpool is not spinning out or aggitating
    Scholar:
  • 116 Answers
Hi this is a bad coupling located between the motor and the transmission, it costs about $10-20, can be accessed by tipping the washer back and getting up underneath you will need to remove the motor, fairly easy job.
Sean
Posted on Mar 27, 2011
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
Whirlpool lsq8243h doesn't aggitate
if it doesn't agitate but will spin it is probably the agitator cams.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285809/470910
If it doesn't spin it is probably the motor drive coupling
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem.
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
Oct 07, 2012 | Whirlpool Washing Machines
Whirlpool LSR8444 washer, timer works but no spin or aggitation
Your problem is a broken drive coupling between the motor and transmission. Replace the drive coupling.
Jul 27, 2009 | Washing Machines
Washer will not spin. Does everything else.
If it aggitates, then the tranny and motor coupling is ok. the drive assembly is bad. nintey perent of the no spin problems is motor coupling problem. But since yours will aggitate, then the coupling is fine.
Jul 12, 2009 | Whirlpool Inglis IP4400 Washer
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Whirlpool Washer wont spin or drain
check your run capicitor
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | Washing Machines
The aggitator (sp?) isn't turning...the rest seems to be working (spin & fill). How do I fix it and is it worth fixing? Model LBT6133A Whirlpool Washer
Go under the aggitator inside the tub and pull out the aggitator it self and check out see if the teeth are strip,If the teeth are strip on the aggitator replace it. If is on the other side then it's not worth repairing. All you need to do is just pull on the aggitor from the bottom.
Apr 26, 2008 | Washing Machines
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
18 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
