Question about kawasaki Air Tools & Compressors
Manual for alltrade spray gun to operate air & paint
  • 2712 Answers
SOURCE: spray gun question
For the most efficient use of the gun, always make a careful check that all parts are the proper size and type, and are in perfect working order before operating. The following items can serve as a checklist: Manifolds and Regulators: The CFM capacity should be at least one and one half (1.5) times the total capacity required by the equipment. A separate regulator should control the atomizing air and all gauges should be readable and in good working condition. Moisture and Oil Traps: In order to assure the least amount of contamination of the Gel coat, moisture and oil traps should be installed and drained daily (minimum) on all air lines at the spray booth. Traps must be installed on the lines at least 25 feet away from the air compressor. Quick Disconnects: Quick disconnects are not recommended for airless or high pressure systems, and may reduce the volume of air and fluids passing through them. If they are used, they should be the largest size available. Hoses: Hoses are used only for delivering air from a regulator on a main air line and fluids from the fluid pump to the gun. The standard hose length is 25 feet and should never exceed 50 feet. Hose capacity should match the volume delivery and pressure demanded by the gun when the trigger is pulled. Hoses must be capable of delivering the material at the volume and pressure rates dictated by the gun. There will always be a pressure drop from one end of the hose to the other.
Posted on Aug 27, 2008
SOURCE: problem spray painting water based paint
I spoke to a friend who was a spraypainter in his last job, apparently due to the thickness of the paint, I needed a larger nozzle on the gun. I couldnt get a nozzle to suit this gun so I purchased another gun with a cuple of different size nozzles. All seems to be working fine now.
Posted on Nov 20, 2008
  • 35 Answers
SOURCE: Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Posted on Feb 26, 2009
  • 5 Answers
SOURCE: will vaper spray gun do latex paint
Yes is the short answer, but you will need to use a latex wet edge extender (X.I.M) makes one most paint store should carry it. You can also use a bit of water, no more than 10% or as detailed on the label.
Keep adding the extender or water until it stops shooting spatter an has a finer mist.
Posted on Jan 28, 2010
SOURCE: operating instructions for central pneumatic
My #91011 One Quart is not a gravity feed, it is air compressor fee fed. My problem is the nozzle will not fan out . It only blows a round spray mist. ?
Posted on Aug 02, 2010
May I have the manual for a WAGNER PAINT SMART electrical spray gun. thank you
nozzle head might be shut try turning it to open, you should here air coming out if air comes out but no paint comes out then paint is to thick and might need thinning, hope it helps.
May 20, 2014 | Wagner Spray Tech Air Tools & Compressors
Paint gun splatters paint on car
The needle valve in the spray head needs to be cleaned or replaced.
Nov 21, 2013 | Binks Paint Spray Gun Repair/rebuild Kit...
Looking for campbell hausfeld airless spray gun ps220a 2/3 hp operators manual Please!
Go to the Campbell-Hausfeld website at http://www.chpower.com/, under the 'Service & Support" tab select 'Manuals/Parts Lists. Do a search for your model number and you'll be presented with the manuals and parts lists for that line of paint sprayers.
Feb 28, 2013 | Campbell Hausfeld Airless Spray Guns &...
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
My paint gun is pulsating instead of spraying evenly
It looks like you have a Devilbiss SRI.
Probaby the hole in the lid is blocked, The gun sprays, paint gets sucked out, no air can get back in through the little hole in the lid to replace so it stops spraying, pressures even up it sprays abit more, and so on.
Either that or you have a damaged fluid tip.
regards
Sep 18, 2010 | HVLP New PROFESSIONAL AUTOMOTIVE AIR...
MY CAMPBELL HAUSFELD DH5300 PAINT SPRAYER WILL NOT SPRAY PAINT.
there are several issues that can cause this problem.
I will assume you have used the sprayer before so that will eliminate an incorrect air cap. The only other issues are paint viscosity, worn parts and the number one cause improper cleaning.
Be prepared for a complete disassemble of your gun. Depending on what you spray any residue can become hard as cement and it only takes a small amount to cause problems.
Below is a link to the manual that gives an exploded view of your gun.
Hope this helps but if not please let me know and I will trouble shoot further.
http://www.cpocampbellhausfeld.com/static/manual/www.cpocampbellhausfeld.com-dh5300.pdf
May 22, 2010 | Campbell Hausfeld Air Comp Basic Spray Gun...
Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
Apr 01, 2010 | Binks MACH 1 HVLP Pressure Feed Spray...
Operating instructions for central pneumatic industrial paint spray gun md 91011
Oct 26, 2009 | RTO Central Pneumatic Gravity Feed Spray...
Paul.
Feb 09, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
Air Tools & Compressors Logo
221 people viewed this question
Top kawasaki Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a kawasaki Air Tool and Compressor Expert? Answer questions, earn points and help others
