Running QuickBooks Pro 2007 and trying to use new version of Check Designer. Despite following all of the instructiuons to set up both programs to print compatible checks, Check Designer will not open when I enter "print" command in QuickBooks
  • 823 Answers
You could just use check designer to make all of your checks and print them. Then use them in Quickbooks as needed for check runs as if they are pre-printed from the bank.
I work for Intuit (QuickBooks) and there are ways to program both to run together but it is not without faults and changes in order to keep it going correctly. In my opinion you would be better if using the method above.
Posted on Mar 27, 2011
I am unable to open Quickbooks Pro 2007. If I try to uninstall the program, I get the message; The following applications are using files that need to be updated: Quickbooks (Process ID: 5932). If I...
You may have to kill these processes before you do an uninstall / repair. Press ctrl + alt + del and select the processes tab. Find anything that says quickbooks or intuit. You could also look for the process ID's you posted. When you find them highlight each and press end process.
Intuit also offers this tool: QuickBooks_Clean_Install_Utility.exe
Regards, Chris
May 13, 2011 | Intuit QuickBooks Pro 2007 Full Version...
I am trying to install QuickBooks Pro 2007 on a new computer that has Windows Vista Business with SP1, and I had updated Windows, then installed QB but when I imported the company file, QB gave me a...
Why is this happening This issue can occur as a result of uninstalling the Google Desktop installed by Quickbooks on a computer running Microsoft Windows Vista. Launching QuickBooks after uninstalling Google will cause the error message.
Note: This issue is also known to occur with computers that have been upgraded from Windows XP to Windows Vista, where Google Desktop was uninstalled under Windows XP. Both cases would yield the same error message.
How to fix the problem This issue was resolved in the latest release for your version of QuickBooks.
Detailed Instructions Please update your program to the most current release.
just click on that link above then click on the 909ffb0.jpg(update) image on that page.
Oct 27, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Download quickbooks 2007 to a new computer.
Hello Michelle,
You can download it here:
For Quickbooks Pro 2007
http://quickbooks.intuit.com/downloads/2007/pro.jsp
For Quickbooks Premiere 2007
http://quickbooks.intuit.com/downloads/2007/premier.jsp
For other Quickbooks 2007 products, you can choose here:
http://support.quickbooks.intuit.com/support/Pages/KnowledgeBaseArticle/1006369
Hope this helps. Good luck!
Oct 21, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Cannot open Quik Books 2007
Windows XP:
  1. Uninstall QuickBooks, Microsoft .NET Framework, and Microsoft Visual C++ 2005 Redistributable:
    1. Close QuickBooks.
    2. Click the Windows Start button and select Run.
    3. Enter control in the Open field and click OK.
    4. Double-click Add or Remove Programs.
    5. Right-click your QuickBooks program version and click Change/Remove.
    6. Follow the instructions to Uninstall QuickBooks.
    7. Repeat steps d through f to uninstall Microsoft Visual C++ 2005 Redistributable.
    8. Repeat steps d through f to uninstall Microsoft .NET Framework for your version of QuickBooks:
      • QuickBooks 2008 and 8.0 and later:Microsoft .NET Framework 2.0
      • QuickBooks 2007 and 7.0 and earlier:Microsoft .NET Framework 1.1
  2. Rename the QuickBooks program folder:
    1. Right-click the Windows Start button and select Explore.
    2. Browse to C:\Program Files\Intuit.
    3. Right-click the QuickBooks folder for the version you just uninstalled (for example, QuickBooks 2008) and select Rename.
    4. Enter OLD_ at the beginning of the folder name and press Enter (for example, OLD_QuickBooks2008).
  3. Insert the QuickBooks CD in your CD drive, and follow the instructions to install the program.
  4. Open QuickBooks.
Jul 09, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Error message Library not registered
I got the message "Line 25: Library not registered" after uninstalling QuickBooks Pro 2009 and trying to run my old version of QB Pro 2006.
(I had installed 2009 version to upgrade my QB2006 Pro version but got into problems with multicurrency support not being supported in the Canadian QB Pro 2009.)
Fix is VERY easy and I think it applies to anyone trying to run an older version of QB Pro after uninstalling a newer version.
Fix is to find the file "reboot.bat" located in the program files associated with the older QB version.
In my case it was found in "C:/Program Files\Intuit\QuickBooks Pro" folder.
Just double click on the file to run it. This file tells the system where parts of the QB program are located including the DLL libraries it needs. After running this file you should be able to run your old QB version OK. No rebooting necessary.
May 08, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Free quickbooks on-line tutorial
Before you uninstall try this Quickbooks link: http://community.intuit.com/quickbooks It is a steep learning curve at the beginning but easy to master in the long run. If you still want to uninstall just go to Control Panel>Add/Remove Programs and choose to remove :) Steve Medley
Feb 04, 2009 | IBM Computers & Internet
Need to download quickbooks 2007 pro
Trying going to this link:
You will need to have your numbers ready. And it may take a while.
Jan 18, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Computers & Internet Logo
52 people viewed this question
Alun Cox
David Payne
David Payne
