Question about Panasonic KX-TGA510 Cordless Phone
When a call comes in it rings one time then stops
  • 225 Answers
This is often caused by a partial short on the phone line. I would first test the line at the incoming interface. If this is a standard phone line(not from a cable company or broadband provider), there is usually an outside interface box where the phone line connects to the building wiring. Open the right side of the box with a screwdriver. In this box there is typically a short line cord plugged into a modular jack(test jack), if you unplug this line cord and connect a standard phone, you will be connected to the phone line but isolated from the building wiring. Make a test call to your number with the standard phone connected to the test jack and if the problem continues then the trouble is on the phone service provider's side and you will need to report the trouble to your service provider. If the trouble does not occur with the phone connected to the test jack, then the trouble is on the building side. To find where the trouble is on the building side you will need to use a process of elimination to test each of the outlets, line cords, telephones and cabling to determine where the short is. This process can often take a lot of time and patience to find the trouble. It may be best to call a telephone tech at this point. If your service is from a cable company or broadband provider, then you will need to test the line at the equipment that converts the cable or broadband into dialtone to determine if the trouble is on the service provider side or the building wiring side. Send a comment if you need more information on finding the trouble in your building wiring, outlets or telephones.
Posted on Mar 28, 2011
I have changed the o ring three time and I cant get it to stop leaking. Two new o rings installed....still leaks.
One solution might be to get a fatter o-ring.
I am not sure where you live, to recommend a source, but they do come in different thicknesses.
Another thing I have done is to buy a silicone lubricant to help that, not to seal it, but to take the stress off the o--ring.
The silicone might also help the plastic threads of the filter.
God bless your efforts.
Nov 12, 2015 | Pool & Spa
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
I need to reset the amount of rings before my answering machine comesd on,it;s model# 1719
Press and hold [SET UP] until the system announces "Number of rings is..." Press and release [ANNC/SKIP] or [MEMO/REPEAT] until the system announces the desired number of rings. Press [PLAY/STOP] to exit. Full details are on page 2 of the manual.
Jun 10, 2012 | AT&T 1719 Digital Answering Machine
Mechanic says that my timing chain needs replacing - but states the pistons may be bad also -- is this true
940 engines run on timing belt. Replacement is needed as per recommendation in the manual. Your are able to check if pistons compression rings and oil rings are bad by carrying compression test, pulling out the oil dipstick while engine is idling and vapour is is noticeable coming out and opening the engine oil filler cap after stopping the engine, vapour is observed then you may have problems with these rings.
Nov 02, 2010 | 1994 Volvo 940
How do i change the number of rings before my fax machine comes on
I have a Brother Fax but not the same model as yours. In mine you select Menu - Set Receive - F/T Ring Time
Sep 24, 2009 | Brother MFC-5490CN Flatbed Inkjet...
Stop the ringing.
in the FAX setup screen you should be able to control the amount of rings before it pick up the phone try that let me know if it works
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | Office Equipment & Supplies
Lux timer will not ring
Your very old Lux timer has timed out and needs to be retired.
Aug 08, 2017 | Lux Hardware & Accessories
Panasonic KX-TGA510 Cordless Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
