Question about Microwave Ovens
Sub-Zero 601 F - when the door closes is re-vacumn seals and take 3-5 minutes before you can re-open the door. Is this time adjustable to something less? This is very inconvenient when working in the kitchen.
    Sergeant:
  • 192 Answers
Q: Why is my door hard to open?
A: Your unit was designed for an airtight seal.
A vacuum seal can form after the door is closed. Wait several seconds for pressure to equalize before reopening the door.
I have had this problem as well. A quick solution is to put a thick straw between the seal and the unit. this usually makes it easier to open. Don't forget to remove it though.
Posted on Mar 27, 2011
RE: Samsung microwave SMH7187STG mfg'd 5/08. I heated cup of tea 2 min.Then I closed micro's door & micro emitted a continuous electrical buzzing sound.I opened door & buzzing stopped.
The cook relay on your control board is shorted, and the unit is cooking whenever you close the door.
When the magnetron overheats, its thermostat opens, shutting power down until the unit cools to a safe level, then power is restored.
I regularly repair these with my $54.95 service, which includes insured return shipping.
Details are here, or for full information and instructions, please e-mail me here at pupista@gmail.com and remind me of your full model number and symptoms.
Dec 20, 2016 | Samsung Microwave Ovens
Kenmore elite micowave still runs after door is closed with no time on menu
The door switch may be adjusted. If not then it will have to be replaced.
Aug 18, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Thermador 01
make this test and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Oct 25, 2013 | Thermador MBES Microwave Oven
I would like to fix a door switch on wolf MW24
The adjustment does not last, the technician should have replaced the door switch from the beginning to avoid a callback and leaving a bad impression. To trouble shoot you will need a digital meter, if you have one one post back.
Jun 28, 2012 | Sub-Zero MW24 Microwave Oven
Door is stuck and will not open. Tea was heated for one minute and did not get hot. Opened door put tea in again and pressed the add time button. After that the door would not open. Unplugged microwave,...
Door catches.
One of the latches may have broken off or got stuck and is not lifting the dother latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Dec 30, 2010 | GE JE1390 Microwave Oven
I inherited a 1986 J.C. Penney Microwave and can't figure out how to program most of the features. I need an operating manual or a gnome.
The clock must be set before you can use the microwave. When you plug it in, it should read all zeros. Enter the time, and press "Clock Set." Time is in 12-hour format. There is no daylight saving time.
For basic microwave use:
1. Press "Power."
2. Press the keypad corresponding to the desired amount of power, e.g., "High," or "Defrost." (The numbers on the keypad have little words on them, like "Warm," "Med," and "High".)
3. Press "Time."
4. Enter the desired cooking time, e.g., "1-0-0" will be 1 minute; you could also do "6-0" for 60 seconds. You can do as little as 1 second, up to 99 hours 59 minutes. "1-0-0-0" would be 10 minutes. "2-0-1-2" would be 20 minutes 12 seconds.
5. Press "Start."
NEVER operate the microwave when it is empty. Put at least a glass of water in it. Never put a glass in it empty; make sure the glass has something in it, like water. Be careful when taking out a glass of water that's been heated; the water has been known, in rare instances, to "explode" and severely scald people.
It is okay to use the approved metal rack (it's coated with ceramic to prevent arcing) when using the microwave in microwave mode. Of course, the metal rack is also fine for use in the convection/combination mode.
"Defrost" cycles between microwave and nothing, microwave and nothing, microwave and nothing. You can hear the cycles. If defrost takes too long, try "Low." Try to avoid using "High," as it kills most nutrients in the food. Opt for "Medium" for slightly longer time; it'll be more evenly heated and healthier. Some things, like popcorn, require "high" power.
To stop the microwave in the middle of cooking, simply open the door. (There's no such thing as microwaves escaping the oven and bouncing around the kitchen and zapping you. I have a microwave tester, and the moment you open the door, all microwaves dissipate; the reading at the door is "Zero" once it's opened.) Or, press "Cancel." If you open the door, you may test the food, and if it needs further cooking, you may close the door and press "Start," and it will resume where it left off. If you're all done, just press "Cancel."
There is no way to disable the 5 beeps at the end of the cycle. If the baby is sleeping and you don't want to hear the beeps, simply open the door right before the beeps when the countdown is at zero. Pressing "Cancel" will give you one beep.
If you have the Combination feature, that cycles between microwave and convection heat, giving the best of both worlds (cooking inside with microwaves and outside with convection), for things such as a whole meats.
To use Combination:
1. Press "Combination."
2. Consult the chart on the microwave (below the keypad) and choose a number from 1 to 4, depending on what type of food you're preparing (i.e., lamb, pork, etc.).
3. Press "Time."
4. Enter the desired time, using the method described above.
5. Press "Start."
The Convection feature simply blows hot air across the food, at the temperature and duration that you set. It's a great way to toast slices of bread for the whole family at once, or bake a pizza.
To use the Convection feature:
1. Press "Convection."
2. Choose the temperature (the degrees are printed on the keypad, such as "350 degrees."
3. Press "Time."
4. Enter the length of cook time, using the method described above.
5. Press "Start."
Be sure to cover foods (with a paper towel or suitable plastic cover) that are prone to splattering. Don't let foods explode and get up into the motor. Clean the inside regularly with a soft sponge and mild detergent, NOT harsh or abrasive chemicals like Comet. Then rinse the soap off with a clean sponge.
Be sure to close the door firmly before cooking, but don't slam it. Slamming it will wear out the latching part, but being too gentle in closing the door may cause the safety switch to not engage, and the microwave won't work (it'll count down and the light will turn on but the motor won't run).
Note: the Convection feature uses more wattage than the microwave counterpart. The volts and amps are listed in the door jamb; multiply them together and you get total watts (although the actual amount will vary depending on your "power" settings).
Aug 07, 2010 | Microwave Ovens
Won't work if just turned on, but will work if you lift door.
there are two switches that are operated by the door prongs as they latch the door closed .. both switches have to be operated to enable the microwave ...you either have something cought in the door seal preventing it from fully closing or one of those switches is out of adjustment .. unfortunatly you have to remove the cabinet to get at the adjustments ... the switches are set so that the door has to be completly closed so there is no RF leakage .. so its a rather critical adjustment .. there is potentially fatal voltage and current inside the microwave so make certain that its not plugged in if you do anything inside ... it would be better to take it to a competent repair person .. that fix should only take a few minutes .. they would have the proper gauges to set it precisely ... if you feel confident that you can do it then you will be able to hear a click as each switch operates as the door is closed .. you should hear two clicks if you shut the door carefully .. loosen the switch that is not operating and move it just slightly until it reliably clicks each time the door is closed .. tighten it there .. make sure the door and its seal are not bent, warped dirty or otherwise damaged ... its a good idea to check for radiation leakage after any microwave fix .. there is a low cost instrument for doing this .. (microwave radiation leakage detecter) ... your repair person would likely have a better one than you can buy .. ...
Oct 07, 2009 | Sharp R-1510 Microwave Oven
MIcrowave runs with the door open also
your door switch is mis-adjusted,furthermore the other safety switch on the door should have blown the power fuse in the unit,because by design for safety it produces a short circuit if door opens under operation,so if door was taken off and replaced it was not adjusted properly
Aug 15, 2009 | Sanyo EM-P790 Microwave Oven
The closed door doesn't always hit the limit switches
I strongly suggest that you do not attempt to adjust the hinges.
The door switch mounts are either cracked or need to be adjusted.
Door switch mount trouble is usually caused by slamming the door.
This may be a little more info that you need and it's from a Sharp service manual, but the general principles apply:
1. Disconnect the power supply cord, and then remove outer case.
2. Open the door and block it open.
3. Discharge high voltage capacitor.
If the door sensing switch, secondary interlock switch and monitor switch do not operate properly due to a misadjustment, the following adjustment should be made.
4. Loosen the two (2) screws holding latch hook to the oven cavity front flange.
5. With door closed, adjust latch hook by moving it back and forth, and up and down. In and out play of the door allowed by the upper and lower position of the latch hook should be less than 0.5mm. The vertical position of the latch hook should be adjusted so that the door sensing switch
and secondary interlock switch are activated with the door closed. The horizontal position of the latch hook should be adjusted so that the plunger of the monitor switch is pressed with the door closed.
6. Secure the screws with washers firmly.
7. Check the operation of all switches. If each switch has not activated with the door closed, loosen screw and adjust the latch hook position.
After adjustment, check the following.
1. In and out play of door remains less than 0.5mm when in the latched position. First check upper position of latch hook, pushing and pulling upper portion of door toward the oven face. Then check lower portion of the latch Figure C-3. Latch Switch Adjustments hook, pushing and pulling upper portion of door toward the oven face. Both results (play in the door) should be less than 0.5mm.
2. The door sensing switch and secondary interlock switch interrupt the circuit before the door can be opened.
3. Monitor switch contacts close when door is opened.
4. Re-install outer case and check for microwave leakage around door with an approved microwave survey meter.
Dec 05, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
231 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
