Question about Rule 1800 Pool Cover Pump With Leaf Protector 110v
I tried my Rule 1800 cover pump to get the spring water off. I plugged it in and it tripped the switch on the outlet. I reset and it ran for about 2 seconds and then quit. I waited a few minutes and tried again - the exact same result. Any suggestions?
    President:
  • 1,489 Answers
I assume the device being tripped is a GFCI -- the pump has a short to ground. Most practical solution is to replace the pump. Don't try to run it from an un-protected outlet (no GFCI) -- it's dangerous.
Charlie
Posted on Mar 27, 2011
We have a new Rule 1800 pool cover pump, which sits on a small tarp in the center of the cover ---- since our pool is surrounded by trees this makes it easier to get the leaves. In a wind storm the tarp...
Sorry to hear you are having trouble with the pump...Thanks to www.automaticpoolcovers.com for pulling this rule warranty information together. They sell many of these with the pool cover systems and their site tells you all you need to know about dealing with Rule warranty issues. You can find that information at:
http://www.automaticpoolcovers.net/pdfs_new/Rule%20Pump%20Warranty.pdf
John
Nov 17, 2010 | Rule 1800 Pool Cover Pump With Leaf...
Trips GFCI outlets
The motor on this unit is sealed and not accessible for repair, only replacement.
Mar 09, 2010 | Rule 1800 H53SP-24 Swimming Pool Cover...
I have a Rule 1800 pool cover pump with leaf protector. The pump will not run while in water, but it will run when not in water. What could be causing this?
You are probally just getting an air lock and can fix this by taking the hose off till it's under water or hold it upside down in water till it starts. If you hold the cord while it's in the water an just make sure it's taught you should be able to feel the vibration through the cord to tell if the pump is indeed running while under water.
If this does not help you may have to take the bottom end apart and check the impeller for clogs.
I hope this helps and good luck.
Jan 21, 2010 | Rule 1800 Pool Cover Pump With Leaf...
I have a Rule 1800 H53SP-24 Swimming Pool Cover Pump. Everytime I plug it in it trips the breaker. Did not have this problem with the same pump a month ago. Tried in GFI and all other outlets. Any...
Hello. There are several possible issues here which are all fairly easy to investigate. Begin by bringing your pump, cord and hose into a warm space for 24 hours to thaw everything out, warm it up and dry it out. Then try it. If it works, you know you have one of the problems described below:
1. Sometimes a circuit breaker wears out and needs to be replaced. Try your pump on a different circuit, insuring that you are using a different circuit breaker. IF it works there, the solution is to replace that worn circuit breaker. 2. Check the impeller and remove any clog, blockage, debris or residue. 3. The 24 foot cord on your pump might have a cut, or a scrape on it. If it does, water is getting into the insulation and causing the circuit breaker to kick. Check your cord thoroughly and if you do have a break in it replace the cord or repair it with a waterproof repair. 4. Your pump motor may be worn or faulty or have a water intrusion. In that case the only fix is to replace the pump. 5. The drain hose could be frozen. If it is, that blockage could cause the breaker to kick. Always ensure that the hose runs consistently downhill.
If you would like to contact Rule, you may do so at the following link: http://www.rule-industries.com/
Regards, Joe. Please rate my answer. Thank you and happy holidays.
Dec 26, 2009 | Rule 1800 H53SP-24 Swimming Pool Cover...
When i plug my pool cover pump in the the gfi outlet trips
The pump motor is likely grounded causing the GFI to trip. Once the seal inside a submersible pump fails, water enters the unit and the motor will fail. The low cost of those pumps makes them not worth fixing and you will most likely need to replace it.
Oct 03, 2009 | Rule 1800 Pool Cover Pump With Leaf...
Rule 1800 pool cover pump trips breaker
It sounds like the pump motor has shorted. Probably time to invest in another one.
Apr 11, 2009 | Rule 1800 Pool Cover Pump With Leaf...
Rule H53sp-24 pool cover pump trips GFI breaker
GFI devices are prone to degrade over time. Also, when used outdoors there are additional moisture issues that may cause sufficient current leakage to trip the breaker.
I had a similar problem this Spring. I was using a 20 amp GFI "master" outlet that protected two additional outlets 'downstream' of it (wired to the 'load' terminals on the GFI outlet- I'd have the check the doc. to see what terminology was used here). The pump was plugged into one of the downstream outlets.
Replacing the GFI seemed to solve the problem. I did ante up $20 for an 'outdoor' model of the 20 amp GFI unit, several bucks more than the standard 'indoor' unit - have no ideal if that represented additional value or not.
Note also, that this is the third such pump I have used for my pool cover. The other two failed to come on at all after about a year's use. The mfg replaced them under warranty (I may have had to send back the old pump - I forget!).
Curtis
Mar 22, 2009 | Rule H53sp 24mgra Swimming Pool Cover Pump...
Rule 1800 gph pool cover pump will not run
The sensor that checks for h20 every 10 seconds may not be working properly. First make sure the pump is unplugged then clean the pump making sure the impeller is free never do this with it plugged in. tap the pump lightly with a screw driver handle to make sure the bearings are not frozen if it still does not work send it back to the manufacturer
Mar 20, 2009 | Rule H53sp 24mgra Swimming Pool Cover Pump...
Rule 1800 Pool Cover Pump With Leaf Protector 110v Logo
304 people viewed this question
Top Rule Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
