Question about Kenmore Washing Machines
I have a Kenmore model 11049962603 that displayed an f-71 error code. I ordered a new cpu computer from sears and installed it. the machine seemed to work for one or two loads. now it displays an f-70 error code and you offer any suggestions to what the problem may be? Thanks Kenny
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
I provided a complete list of error codes for this type of washer in the image below. The error codes vary by the exact model of HE3t washer that you have. Since you have an HE3t that is displaying the F70 and F71 codes, the list below should apply to your model. These are not listed in the owner's manual because they are intended for technicians. Use extreme caution if you follow any of the troubleshooting described in this information sheet. Unplug the washer and shut off the water supply before accessing internal components.
The F70 and F71 codes indicate that you have a communication error between the CCU (Central Control Unit or main machine control board) and the user interface touch pad assembly. Here are some troubleshooting tips:
Make sure that you have the washer plugged into a properly grounded 3 prong 120 volt AC electrical outlet.
Unplug the washer for 30 seconds to allow the control boards to power down and reset. Plug the washer back in but do not touch the power button (or any other buttons) for 1 full minute. This may reset the control board. Pressing the power button too quickly after reapplying electrical power to the washer can cause the F70 or F71 code since the CCU does not have time to recognize the user interface control.
If the above tip does not help then the most suspect component failure is the MCU (motor control unit -- motor control board at the bottom of the washer beside the drive motor). You can check for this failure by unplugging the washer and then pulling the MI3 connection on the CCU. The wiring diagram below has the MI3 connection highlighted in red. The connection has blue wires. The third image below shows this connection on the control board. The connections are labeled on the control board. Press the tab at the bottom of this plug down and then pull it out. Power up the machine with this connection unplugged and don't touch any buttons for 1 minute. If you then press the power button to turn on the washer and don't get the F70 or F71 code then the MCU at the bottom of the washer will likely need to be replaced to fix this problem. A technician would normally be needed to verify this failure and replace the MCU. The MCU is expensive ($423).
This troubleshooting information is based on a common HE3t model that displays the F70 and F71 codes. If you need more help, submit additional details and the full model number of your HE3t washer.
I have a Kenmore model 11049962603 that displayed - richroth_125.jpg richroth_126.jpg richroth_127.jpg
Posted on Mar 27, 2011
  • Nigel Gentry Dec 08, 2011
    Many thanks for this answer, Richard. The repair man from Sears told me that it would cost at a very minimum $800 to fix my machine and that there was no way of telling which of 3 boards was causing the problem. Using your diagnostics, I found that it was the MCU, managed to buy one on e-Bay for $180 (+$15 shipping) and replaced it myself. Thus saving a fortune! :-)
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Kenmore HE2 Plus Model# 11047512600 When pushing the start button it will just beep 3 times and not do anything, door won't lock or start cycle. No error codes are displayed. Whats wrong?
Hello Jason,
Regarding
  • There is a communication error in the control board.
  • Also the door Latch assembly may be defective. Check & replace as necessary.
Here is a link to Sears parts direct.
KENMORE RESIDENTIAL WASHER Parts Model 11047512600 Sears PartsDirect
Jun 25, 2015 | Kenmore Washing Machines
FF error code - fills up & won't drain
sorry but we have the same problem that the sears repairman had no model number gives us no choices . suggest you buy a new machine, but not Sears brand as they seem to be going out of business world wide
Oct 26, 2017 | Kenmore Washing Machines
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Can these needles be used with my sewing machine?
Don't know if this is helpful...but I have a very old Kenmore and 2 Brothers. I used the same needles with all 3 machines. No problems.
Apr 13, 2009 | Sewing Machines
I'm trying to purchase a new Model 29732 kenmore washer
It is no longer available.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 07, 2009 | Kenmore Washing Machines
F1 Error Codes
sorry to be the bearer of bad news, but its the machine/motor control unit (circuit board). if you don't want to involve sears to get them to pay a portion of the bill, then go to searspartsonline and order one yourself. you'll need your model number to get the right part number ECU (which should be W10189966 rev A) which will run you about $150. replacing it is relatively easy is you're handy at home. sears service will charge you another $130 to install it. this will fix the F1 problem.
not sure if sears has finally recalled this washer. if they finally do, then all our problems go away (yeah, right).
Jan 18, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore He5 dryer, a service code f22
just remember error codes are always going to be stored on every machine ,, shoukd not have a problem ,, but does it work
Nov 29, 2008 | Kenmore Elite HE4 Electric Dryer
Machine error 71
Error code 71 -- ( Polygon motor does not synchronize with the reference clock. ) What ever that means - hope that helps.
Mar 20, 2008 | Brother MFC 9700 All-In-One Laser Printer
Washing Machines Logo
526 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
