Question about Quantaray Rapid Battery Charger with 4 Rechargeable AA Batteries - 1-Week Holiday Sal
CHARGER NOT SHOWING ANY KIND OF INDICATION THAT UNIT IS ON OR NOT
    Scholar:
  • 122 Answers
You need to insert two healthy cells (together on either side) before the indicator will illuminate.
If it doesn't, then the charger might be faulty.
Open circuit cells will also cause the same symptom, although it's very unlikely that you willl get more than one out of four failing. Dropping a cell can cause unpredictable results.
Posted on Jun 07, 2011
Battery indicates being charged but is not being charged.Is this an indication that battery is in need of replacement
if the screen is showing that the battery condition is charging then power is getting to the battery
whether the battery is accepting charge or not would depend on the battery condition
if the charge light is on the charger ,it indicates that the charger is working but not necessarily supplying a charge to the battery
I suggest that you take the phone and the charger to a shop that specialises in batteries and have them both checked out
Jun 27, 2015 | Nokia E Cell Phones
The led on my kenwood KFC-W3534A won't come on
It can be the issue with connections or power issue or also the board issue.In some cases all checked out ok,but the actual problem comes out to be the short is display panel,which power the led.------Also how old is unit and what exactly caused this problem,is there any kind of other indication showing up like,loose wire or erratic noise coming up,with no power .Etc etc,,-------Click this link below :----
http://technoanswers.blogspot.com/2012/01/every-question-has-answer.html
Thanks.
Jan 26, 2012 | Kenwood Car Audio & Video
BATTERY SHOWING CHARGING, BUT SHOWING 0% AVAILABLE
This is an indication that the battery is dead. A dead battery won't accept any charge from a charger. If the laptop will operate when plugged in with or without the battery, it's a bad battery.
Nov 09, 2011 | Computers & Internet
Hi, my blackberry Curve isnt charging and ive tried several chargers, there is no light indication showing that it is charging what do i do? i dont have enough money for a new charger HELP
This kind of fault is only limited to a few causes.
First of all, it is not likely that all chargers you have tried are bad. So the fault is definitely coming from the phone. it is most likely that the charging port on the phone is bad and needs replacement of needs to be worked upon. This may not be very expensive depending on your location and the extent to which the damage has been done.
Also, it is very possible that the power source is not good enough to charge the phone. As such, you might be required to plug the phone's charger into a number of outlets that you are sure are operating fine. This would help you determine if the fault is coming from the charger, outlet or phone.
Lastly, if you are just trying random chargers, you would have to get a charger that you are confident is working and you have to try it. If it still doesn't work, you have to send it to a repairer as trying to fix the charging port yourself could let to a more serious damage to your phone.
Hope this was helpful?
Jun 19, 2011 | RIM BlackBerry 7290
Nuvi 660 ~5yrs old. With auto charger connected the unit powers off quickly with low battery indication. However if charged overnight on a USB cable the unit operates fine and indicates the battery is...
You probable have a blown fuse in the cigarette lighter adapter.... Unscrew the silver tip of plug and check fuse..... be careful its spring loaded..
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
Toner showing low but its refilled newly
By using refilled toner cartridges you will always get this type of indication becuase the chip on the cartridge cannot be reset. The best kind of refills to purchase are when they replace the chip and other main components on the cartridge such as the chip and drum unit. If they are only refilling the same cartridge over and over again and not replacing these main components you will start seeing quality issues to your print.
May 28, 2010 | HP LaserJet 4 plus Printer
Garmin 530 doesn't turn on
if the light goes off it would indicate that the battery is fully charged.
does the unit function like a phone when charging as in showing a chg indicator even if it is off? If so there are more serious issue than maybe just a bad power switch.
Oct 22, 2017 | Garmin Rino 530 GPS Receiver
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
Quantaray Rapid Battery Charger with 4 Rechargeable AA Batteries - 1-Week Holiday Sal Logo
184 people viewed this question
Top Quantaray Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Quantaray Hardware and Accessory Expert? Answer questions, earn points and help others
