Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
Model # PDS22SFSBKSS Bottom Freezer. Its making a clicking sound a couple of times a day and the temperature control is not setting. I set it back to 0 for freezer and 37 for refrigerator, but it doesn't hold.
    Scholar:
  • 116 Answers
Hi you need to replace the main motherboard, depending on the age you should call GE if they service your area they will discount the cost of the repair if it qualifies and its cheaper than doing it yourself, if it doesnt qualify then the board usually is around $175.00 just to buy not including to install if you have it installed, this needs to be done quickly prolonged use with bad motherboard on this model will damage sealed system, ruining the entire refrigerator. If you need further assistance let me know.
Sean
Posted on Mar 27, 2011
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
That's interesting, -10 or colder is too cold and something is defiantly going on. This unit is controlled by a mulitple control boards, temperture sensors and other components. Question, what is freezer temp set at? Try increasing it by 3-4 degrees and see if that changes anything. Beyond that, I'm going to change the temp sensor first before doing any of the control boards. #29 is the temp. sensor. Good Luck
Sep 19, 2017 | KitchenAid Refrigerators
Kenmoore 76523 ss bottom freezer, freezer works, refrigerator does not
This is not my main field of expertise . However, as I see you are not getting more support I can address you to this link. It may help you
goodbye
Feb 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
My Whirlpool side-by-side refrigerator/freezer (Model # ED5PHAXSQ00) has power and lights but will not cool or freeze.
Replace the main control board located on the left rear mid side.you can get the board from a local appliances parts store. They will need the model and sereal numbers
May 15, 2016 | Whirlpool Refrigerators
Hi, my Jenn-Air #JF12089AEPO bottom freezer drawer is beeping consistently and the temperature reading shows 18 degrees Freezer Max Temp. There is also a dry frosty crust on most of my frozen foods. How...
Make sure the freezer drawer and the refrigerator door are shutting properly. Sounds like air is getting in causing the frosty crust. Also be sure to reset the controls back to the original mid-way settings and allow a day or so for it to balance, if you have turned the fresh food compartment down to a lower temp it may cause a similar condition.
Feb 24, 2014 | Jenn-Air JFC2089H Bottom Freezer French...
I have an amana BB20 refrigerator that I just replaced the temperature control in the freezer because it went bad.
Sounds like the control flap between the freezer and refrigerator is not opening. Could be a wire on the controller that is not plugged in properly or maybe the freezer is not on temperature yet. Also check your settings on the control panel. Make sure the refrigerator section is active.
Oct 06, 2017 | Refrigerators
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
I have a Magic Chef fridge. For a while now, food is "warm" one day and then it is frozen the next. The same situation is occuring in the freezer where ice cubes trays have thawed and are...
I would suspect a problem in the defrost circuit. I would find the model number on the
inside left of the bottom compartment. Usually when this occurs I replace the defrost
timer as well as the defrost termination thermostat. It sounds as if the defrost circuit
is remaining energized. The parts total should be around 40 dollars. The timer is located
under the cold control cover and the defrost termination thermostat is attached to a
tube in the freezer compartment behind the back panel. These are easy items to replace, the
most difficult part is removing the control panel and freezer cover (each usually has 4 screws)
and a couple holding the tray and vent stack in place.
Make sure to unplug fridge before any work is performed.
Apr 25, 2011 | Magic Chef Refrigerators
Ice Cream Melting...
the ice on the evap may be the clue. there should not be excessive ice build up and if this has occurred, the ice can jam the fan. try removing the freezer back panel, defrost with a hair dryer, reassemble and see if it works. if it does, the fault lies with the defrost system
Jul 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
414 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
