Question about Dishwashers
When using my dishwasher it smells like burnt rubber and it will not drain any water?
    President:
  • 1,140 Answers
Hello -
Firstly, you should stop using - or trying to use - the washer. Any burning smell indicates something is overheating and something may be melting. Further use of the washer will only result in further damage and more expense to repair.
Secondly, it's difficult to assist you without knowing the brand and model number of the dishwasher and the following details:
1. Is the burning smell present at all times during the wash? At what point in the wash cycle do you first notice the burning smell?
2. Is water circulating inside the washer - can you hear it spraying?
3. Will the washer drain manually if you press (and possibly hold) the cancel / drain / reset button?
Please reply to me with the brand and model number and the answers to the above questions by clicking on "Add a Comment" below your question.
Thanks,
BElectric
Posted on Apr 04, 2011
Water backs up from the drain in my dishwasher and smells. what is the problem?
Two things can cause this problem:
1. The check valve in your dishwasher may be defective, allowing water and food debris to seep (or run) back into your dishwasher.
2. Your drain hose may not be "mounted up" the way it should be. Look under your sink. Look at how your drain hose is connected to your garbage disposal. If the hose runs down to the floor of your cabinet and into your dishwasher, that is wrong. Instead, it should be mounted up so that water from the sink and garbage disposal would have to flow up first to get into the dishwasher. If you do this, then even if you have a bad check-valve in the dishwasher, it will prevent the problem (or greatly reduce the problem) of dirty water flowing back into your dishwasher.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
May 17, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Bosch dishwasher smells burning rubber
Certainly could be a pinched wire in the door panel. I would remove the panel and see if anything is pinched or being interfered with like the rinse dispenser solenoid.
Dave
Jul 04, 2017 | Bosch Dishwashers
What is causing the bad electric smell from my dishwasher?
one or more components is burnt on the board of the unit. Or there might be a bridge of wire which is causing the smell....
Jan 05, 2012 | GE Dishwashers
My dishwasher won't drain. Repair man is telling me the motor's burned out. Does this sound right?
Chance are there. If repair man says motor is burnt, he can always show you the motor. You can easily smell the burnt smell.
Let him replace the motor and collect the old motor. that is the only way you can make sure. Hope the repairman has checked all the the other points. Before replacing the motor, find out the reasons for motor getting burnt! No water seepage into the coil, no high voltage in your area etc.
Sep 17, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
My dishwasher will not drain the water out.
Usually this is the drain solenoid. It's usually behind the lower cover. You may be able to smell an acrid (burnt electrical) smell when you take off the cover. The part isn't too hard to replace on most dishwashers, and shouldn't cost more than $20 or $30. MAKE SURE YOU TURN THE POWER OFF FIRST!!!
Aug 27, 2009 | Frigidaire Dishwashers
E5 keeps coming up and now it smells like burt rubber
E5 is water at top probe when starting rinse. If you have burnt smell, it's probably the sump heater on with little or no water over it. Clean and check the 3 probes and their connectors.
Aug 05, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Spinning slow and smells like burnt rubber. Draining very slowly.
Pull drain plug at bottom of machine put tray under it check belt
Dec 18, 2017 | Amana NAV2330AW Top Load Washer
Dishwashers Logo
292 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
