Question about Zenith R57W46 57" Rear Projection Television
Red and green doubled words on tv is this a bulb problem
  • 10,594 Answers
No, it is convergence problem due to convergence output chips failure in rear projection tv.
Local tv repairman will fix it because it requires soldering work to replace bad chips in circuit board.
Thanks.
Posted on Mar 27, 2011
  • 1030 Answers
SOURCE: samsung hdtv has a problem
this points to a convergence amp problem. in customer setup do you have and control or movement on convergence adjstment
Posted on Mar 26, 2008
daniel719
  • 240 Answers
SOURCE: Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Posted on Jan 13, 2009
welcomejee
  • 10594 Answers
SOURCE: Double vision in red and green
Its failure of convergence ICs and will be replaced.
Convergence ICs are mounted on silver heat-sink on D board of TV
Let me know exact model number to help you with more technical info.
Posted on Mar 21, 2009
repairtech99
  • 767 Answers
SOURCE: double vision w/ red & green tint
This is a comon problem
There are two large convergance chip's
the are failing .Replaceing them will
corect the problem . The chip range
in cost from 16,00-30.00 .There cheap,
so dont let the shop over charge you
for parts when and if you decide to
repair it.
Posted on Jul 03, 2009
ladywinn
  • 5138 Answers
SOURCE: I have a sony projection tv KP-46WT500 and have
Replace Both of your convergence ICs STK392-??? they are big black ICs will have part number on them also CK pico fuses they look like resistors but are fuses they will be yellow or green will be around ICs.
Posted on Aug 08, 2009
Magnavox tv model 51mp392h/17 words on the bottom are double one set is red other set is green
Thats caused by failed convergence ICs and the 6.8 ohm resistors. You can get the repair kit called the DPTV305 -DPTV345 & MAG01 chassis convergence repair kit which fits your model. The kit has the components and the CD with repair instructions and its available at the following link top of the page. http://tvrepairworld.com/phillips__magnavox_repair_kits
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
Just replaced bulb and the tv still does not work? the green light flashes 9 times and the red light is solid
Howdy;
Double check the Lamp installtion. 2) make sure the Lamp DOOR is properly closed. 3) unpug TV from a/c outlet for about 5 minutes. pug back into a/c source.
Are you sure the green light is blinking and not the red light?
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
I have a sony projection tv KP-46WT500 and have red/green shadows around the people plus some double word image that are red & green. On the tv guide the station #'s are double and green and red.The...
Aug 08, 2009 | Sony KP-46WT500 46" Rear Projection...
I have double lines in red and green and double words
It sounds like you need to adjust your convergence. If this is a projection TV with CRT's (3) which it sounds like it is there may be an option in the menu to setup convergence. Difficult to tell without knowing the model number and type of projection TV (CRT, LCD, DLP)?
Jul 11, 2009 | Philips Televison & Video
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
Green and red colors seperated
Other than the menu, does the picture look ok? Does the menu just stay there and not go away?
Oct 10, 2008 | Televison & Video
Green screen
It sounds as thought the lower light strip has malfunctioned & blown the red/blue LED lights leaving only the green bulb functioning, I would ring the makers repair team for a repair if it's under warrentee or a repair quote, if warrentee has expired, from my personal experience showed me that a new TV is cheaper. I hope this helps.....
Feb 21, 2018 | Philips Magnavox 51MP392H Rear Projection...
Seeing alot or green lines, test somewhat double vision
there is a screen the light shows through to project to the screen when this starts to fail the screen will have lines. it sits at the end of the light chamber. these are expensive to replace on some models.
May 30, 2017 | Mitsubishi WS48511 48" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
80 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
