Question about Sanyo Televison & Video
Keeps blowing the 4a 125v fuse inside when I turn the power on
    President:
  • 1,623 Answers
Then there is a fault with the power supply in the tv
Posted on Mar 27, 2011
Put new 125V 4A fuse in and it keeps blowing it out.
Something on the powre supply board has shorted out.
Repair the board or buy a new one.
Dec 03, 2015 | Magnavox 32MF301B/F7 32 in. LCD TV
Massage chair fuse on it keeps blowing Model iRest SL-A08-3L
Get its PCB checked for any shorting or ask a technician to brush up the whole pcb with some alcohol and try 5A fuse instead of 4A. You can also look for latest Jade massager bed Carefit 5000 which is more advanced than a massage chair
Jun 04, 2012 | Health & Beauty
It keeps blowing the 4A-125V fuse every time I plug it in...
There is something shorted in the system. often it is the audio output which fails especially if it is run at high volume levels. Unless you are trained in electronics, I suggest you find a repair shop that repairs audio equipment. (Sorry) Hope this helps
Jan 03, 2011 | JVC MX-D602T Shelf System
I have a Brother HL2140. It was plugged into a 220v outlet, is there a fuse that can be replaced?
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 15, 2010 | Office Equipment & Supplies
Keeps blowing the fuse inside the unit.
When a fuse blows suspect an overload in either the power supply or main amp stage. The most likely cause is some part acting like a piece of wire instead of doing it's job. In the power supply it could be the transformer, voltage regulator, or the rectifier or any diode. In the amp section any semi-conductor on the heat sink.
Check first for burnt or damaged parts. If you have a multimeter any transistor or diode will quickly show up. For when you have the meter on the ohms setting and touch the terminals with the probes, it will show as if you had touched the probes together.
Apr 02, 2010 | ButtKicker BKA1000-4A Amplifier
Home Amp fuse keeps blowing
This usually happens when there is a problem with the main power supply and is relatively rare. If you can post the make and model, I can give you some things to check if you are somewhat familiar with electronics.
Thanks,
Dan
Feb 19, 2009 | Pioneer Audio Players & Recorders
Sylvania edtv ld200sl8
will not power. the fuse 4a 125v blows immediately when plugged in.
Sep 04, 2008 | Sylvania Televison & Video
Sanyo tv blows fuse when you turn it on
u have a short in the power supply section
Oct 24, 2007 | RCA F27242GY 27" TV
The tv keeps blowing fuses
Hi your problem is that a component(s) inside your TV has probably short circuited to Earth, this then causes a massive current to flow and this blows the fuse. Due to the types of Component failure from this, this TV should go to a reputable repair shop. Get a firm "Quote" and an explanation of what needs to be done.
Aug 14, 2007 | Sylvania 6432GG 32" TV
Televison & Video Logo
101 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
