Question about Samsung WF206ANS Front Load Washer
I have a wf206ans machine and today i had error code that looks like (be) or (he) i cant find the manual for this machine .this code appears on all cycles for the machine washing or spinning only . any help would be nice thx
Nd (not draining error) this model doesn't have the debris filter as in some models behind a small door. Got the water to drain out manually. can't find a part number for the pump. is there a way to test to see if its the motor or the pump itself. I have the pump assembly out. Please help!
Read more: http://forum.appliancepartspros.com/washer-repair/83224-samsung-washer-nd-error-code.html#ixzz1XOk8Z7yg
Posted on Sep 08, 2011
  • Samsung Master
  • 5,479 Answers
The manual for the WF206ANS is available here: http://downloadcenter.samsung.com/content/UM/200701/20070131100335625_WF317AA_XAA_02291A.pdf . The table with the code list is on page 22 of the pdf (page E-3). A bE error is a motor speed sensor error. If the code reappears when you restart the cycle, then the washer needs service. For other codes or for service, call 1-800-726-7864 (1-800-SAMSUNG).
I hope this helps.
Posted on Mar 27, 2011
Error code E3..
Manual is here
http://demandware.edgesuite.net/aabh_prd/on/demandware.static/Sites-ES-Site/Sites-ES-Library/default/v1427954440473/support/manuals/CWD1510W.pdf
Apr 02, 2015 | EdgeStar 2.0 Cu. Ft. Washer Dryer Combo...
LG washing machine error code 0e....filter clean and machine level but still have error code
The drain pump on the machine could be faulty. This pump cannot be repaired it will have to be replaced if found to be faulty.
Sep 08, 2014 | LG Washing Machines
What is code error F50 on my miele W3725 washing machine mean
I have today purchased a Miele 3985 machine with a know F50 Fault code appearing
Before I went to the expense of calling a Miele technician, I explored the blocked / clogged drain path
I removed the drain pipe and noticed there was a lot of 'residue' / gunk in there
I cleaned what I could, and blew through the pipe back into the machine
Then I did a cotton wash cycle at 90degrees, with a 1litre of bleach to clean the drain path
The wash looked extremely dirty during the cycle
It appears that this resolved the F50 fault code issue with my Miele 3985 Navitronic
Aug 08, 2014 | Washing Machines
Error message of
That means overflow. There is too much water in the drum. Turn the unit off and it should drain. If not then it might be a sensor that is bad.
Dec 03, 2013 | Samsung WF206ANS Front Load Washer
I have a Faema X2 Grand Italia C/10 NF and looking for descriptions of error codes (specifically #055). Is there a manual that gives such information?
ERROR 055 IS KTY PLUGS TO THE GROUP IN MY MANUAL,I'M A TECH AND THIS IS WHAT THE DESCRIPTION SAYS IN THE X2 TECH MANUAL... under possible causes it says either KTY disconnected or Malfunctioning card..solution is to open the machine CHECK CABLING/REPLACE KTY/REPLACE THE CARD.. hope this helps!!
May 09, 2012 | Faema Coffee Makers & Espresso Machines
I keep getting a nf error message. what is this
water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
Dec 31, 2009 | Samsung WF206ANS Front Load Washer
Not spinning or draining Samsung front load wf206ans/xac
Won't spin if it hasn't drained. Most probably a blocked/jammed pump impellor. Manually drain it from the lower drain pump (by side tube if that model has one, or slowly into a shallow pan. Remove cap completely & check for things jamming pump.
Dec 12, 2009 | Samsung WF206ANS Front Load Washer
F1 error code on cabrio washer
Call Whirlpool at 800-253-1301 in USA. There is a recall on this washer for the F1 code. Service call and parts are free. I just did it today.
Jan 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Samsung WD-J1255 Front loader Washer/dryer combo
I have a similar problem with the FE Code. All i have manage to ascertain is that if you set the spin at 400 it will complete the cycle
Nov 01, 2008 | Washing Machines
Casio PCR-T2000A Cash Register
i have a casio cash register pcr-t2000a and i keep getting an error code e 026 enter condiment then preperation plu no matter what i do i cant seem to get it fixed it wont let me use the register with this code
Aug 29, 2008 | Casio Parts Cash Register PC Desktop
Samsung WF206ANS Front Load Washer Logo
382 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
