Computer wont boot
The system will not boot, when I press the power button, the only thing that happens is the fans come on, the keyboard lights flash on for a split second
    Sergeant:
    Champion:
  • 327 Answers
Welcome to fixya
this sounds like a hard drive problem you might need to look into buying a new hardrive
sorry i could not be more help have a good day
Posted on Aug 04, 2008
Am5630-u5202a acer aspire desktop windows vista, i press the button on the front it lights up the led inside and stays on but the computer itself wont. ie cpu fan ist turning or case fan or getting the...
Have you checked the keyboards light? Is it lit? When you press on the CAPSLOCK button, does the light changes in the keyboard?
Try to unplug the hard drive, and DVD from the mobo and see if it goes well.
If no go, try removing the RAM sticks and see what's on the screen when you turn it on. Then put each part back one by one, checking the computer for any change or something like that.
Dec 16, 2012 | Computers & Internet
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
Black screen no cursor no keyboard use
When you powered on the machine did you hear any beeps, hear the fan running, the disk drive running, lights blinking, hear the cd drive click, see the light on the cd drive door for a second or two when it clicks? If these things are happening you are getting power. If not, your problem might be with your power supply, hard drive or motherboard. Remove the power cord, then press and hold the power button for 30 seconds, then plug it back in and press the power button. if it boots you had a static charge. If you get nothing at all but a silent system your power supply is bad. If it sounds like your computer is running but you can't see anything on the screen you might have a problem with your screen or video card. If you have another monitor try using it and see what happens. if it works so you can see things then your monitor was bad. If it does not work with another monitor but you still hear fans, and see lights and hear the disk drive spinning, then your video card is probably bad.
Mar 17, 2012 | Gateway Computers & Internet
My Sony Vaio PCV-RX860 won't boot and makes a clicking sound.
It's usual that new desktop PC's have fans sounds and keyboard LED's flashing during booting..There's nothing wrong on that, as long as you can get in to your PC OS.
Jun 06, 2010 | Sony VAIO Digital Studio PCV-RX860 PC...
The computer will boot but there is not thing on
There was a proble with RAM or motherboard,
  • press the power button and see keyboard (num lock) light (right side of keyboard) is blinking thats means RAM problem in your system
if you are able to open the system,unplug the power cable and open the side cover of CPU,four slod in your system check how many RAM's in your system.if you are using two RAM's of 512MB and than remove the one RAM vis a virsa and plug the power cable than start the system,
  • press the power button and see keyboard (num lock) light (right side of keyboard) is not blinking thats means motherboard problem in your system
please go good shop and replace it.
Thanks,
Dec 16, 2009 | HP Pavilion a320n PC Desktop
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
proton
Nov 07, 2009 | E-Machines eMachines Desktop PC
Ps3 wont eject just turns itself off
Try booting the system while holding the power on button. Hold the button and keep it held until it turns off. After the system shuts off, try turning it on normally. Let me know if this helps.
Sep 15, 2009 | Sony Playstation 3 (PS3) Console
Laptop Won't startup Vostro 1500
See if you can run the Pre-boot System Assessment (PSA) diagnostics. To run the PSA+ Diagnostics on this system, perform one of the following actions:
1) Hold down the <Fn> key while pressing the power button.
2) Turn on the system, press <F12> at the initial Dell™ logo screen, and select “Diagnostics” from the boot menu.
3) Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message “Diagnostic boot selected” displays. The system then launches the PSA+ Diagnostics.
According to Dell specs, there is no error code listed that you described, (Flashing Caps LED). Also try reseating the memory modules, (you might want to try this first).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 07, 2008 | Dell Vostro 1500 Notebook
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
Computer wont start
Nothing is booting ......when in earnest I say that is the BIOS screen at the beginning not going too. When you say the lights all go but the computer does not BOOT can you clarify please what goes. Now you say the processor fan does not work I imagine you are INSIDE the unit to know this try pushing down on the CPU firmly with your hands it may have dislodged slightly it can do this sometimes.....Ive seen it happen. Now for the not booting I need to know what is if any?.
Sep 05, 2007 | Compaq Armada E500 Notebook
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
