Question about Acer Computers & Internet
MY ACER ASPIRE 1640 LAP TOP WILL NOT STAR UP. WHEN TURNING ON THE POWER BUTTON FLASHES ON AND OFF. WHEN PLUGGED INTO THJE MAINS THE CHARGING LIGHT SHOWS YELLOW BUT THE COMPUTER WILL NOT TURN ON
  • 1,031 Answers
Check the power supply to the mains where the lap top is plugged and comfirm if there is power supply and for any possible drop in power output which may affect the charging
Posted on Aug 04, 2008
Hi ive got a acer aspire z5610 ane the power button keeps flashing orange when pluged in from the mains
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Blinking codes to many popular brand lap-tops are given. In most cases, yours will be due to a weak battery inside it, which do not take charging current. Check it first by replacing the battery.
Oct 28, 2014 | Acer Aspire Z5610
Model: Acer Aspire E1-571 The battery had
The battery may have failed even though new.
Apr 24, 2017 | Acer Aspire E1-571-6650 Laptop
Acer aspire 7551 Battery will not charge.
I had a similar problem with a laptop years ago...Where the battery terminals connect to the motherboard, and Im not sure about yours because the models are obviously way different, but in some, they use "battery boards" that connect to the motherboard and are seperate from the system. Those "battery boards" have lots of micro capacitors and resistors on them and are responsible for charging the battery and completing the power circuit to "start" the computer. If I took the battery board out of the laptop I had, the whole thing wouldn't work. Since your laptop is starting while plugged in, but the battery is not charging...I would look into this area first. I am going to rummage around to see if I can find a schematic of your laptop and maybe some parts info.
Jun 20, 2012 | Acer Aspire 7551-7422-22085
When i push the power button my lap top makes a noise lights up for a few seconds then all the lights go out
It isn't getting enough power. Try pluging it in for an hour and make sure the charging light comes on. The battery doesn't have enough juice to run the computer. If it does not charge or won't come on even when plugged in, there is a problem with your cable or charging port, and need to get it repaired by a computer repair company.
Aug 15, 2010 | Acer Aspire 6930-6455 Notebook PC
How do i reboot m y 5515 acer aspire lap top
Click the start button (Or the windows icon - typically lower left on the task bar). Choose Restart. If you can't find that, choose Shutdown, once the laptop is off, press and hold the power button till you see the power come on.
May 26, 2010 | Apevia Acer Aspire AS6530-5514 Laptop
My acer lap top key board is doesn't work
Try to turn off the acer laptop, remove the cables and battery . Press & Hold the power button. Then replug cables and battery. Turn on pc and if symptopm persist, consult acer tech support at 1-800-816-2237
Dec 14, 2009 | Computers & Internet
Acer aspire 5520 wont power up.. no charging light when connected to mains
Try another charger. If it turns on and chargers the unit you are currently using needs to be replaced. Do not leave your charger plugged in after charging your battery as this will shorten its life.
Oct 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5633WLMi Laptop
unplug everything that isn't necessary to run the laptop ie, external mouse, battery, etc. Then plug the ac adapter in, making sure the switch for 110/220 is appropriate for your region. Now, does the machine turn on? PLease respond with the answer, and we'll go from there. Good luck
Sep 04, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
132 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
