The black and white power cord came out do not know where it goes
  • graeme ian hunter Mar 27, 2011
    which motherboard and is this a 2 pin or 4 pin or multipin cable
    Guru:
  • 433 Answers
Dear mother board type i need or snapshoot the cord as you say what is writen on every cord i wait reply thank you
Posted on Mar 27, 2011
Can I replace a white, black, and green wire pattern with a black and white wire pattern
yes u can as long as you know which color represents the hot the ground and the common
Mar 06, 2016 | Dryers
Cut the cord. what is the color code of the wires? I have a green, black and a white wire.
Hello, black is the line or "hot" wire. White is the neutral and green is the ground wire.. On the cord end the black goes to the smaller of the two parallel blades and the white to the larger. The green goes to the one that is more round, the ground.
Feb 20, 2011 | Philips Power Strip 6-ot 8
Power cord was ran over by lawn mower and cut into a black and white wire from inside was unplugged at this time I need to know where does white and black wire plug back in
Is this 110 volt or 220 volt?
110 = white wire goes to the neutral side of the circuit ... or the silver color screw on the plug. The black wire goes to the brass color screw ... or the "hot" side of the plug. The green wire goes to the green screw.
220 = youwill find on the 220 20 amp plug there are two brass colored screws + a green screw for the ground.
Aug 22, 2010 | Intex '10 Saltwater System Pool...
Need wiring schematics for Haier HWR12XC5 AC
My friend ... you are doing a simple repair ... you don't need a wiring schematic to replace this power cord. When you get the unit open ... you will find the other end of the ripped cord ... black goes to black, white goes to white green goes to green or ground. In fact ... you will trim the end of the cord and reattach it using either crimp connectors or wire nuts.
Thanks for your interest in FixYa.com
May 31, 2010 | Heating & Cooling
New adcom7807 shipping ,1 white wire from power cord came off inside ,dont know where to connect.
white is ac low and black is ac hot.if this is inside the unit? then the black goes to the fuse to a filter and the white goes to the same filter. (two seperate pins) .
Mar 06, 2010 | Audio Players & Recorders
Need help with the wiring on the reddy heater 110 btu
CIRCUIT CARD-
-Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order)
-Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR.
-potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL
-Black wire from switch to terminal marked L1 BLACK
-White wire from power cord goes to terminal marked N White
-Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER-
-White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above.
-Black wire from power cord goes to swtich terminal marked 4B
Nov 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
I want to replace just the 3 wire receptacle head of my clothes dryer. there are three wires in the cord. white, black, green. i unscrewed the head and I dont know where which wire goes.
white and black are power green is ground the ground should be marked on the plug the black and white does not matter as long as the are on the power terminals they are across from each other the ground is by itself at bottom of plug W B
G
Jun 10, 2009 | Whirlpool LER4634J Electric Dryer
Power cord wiring, what is each color?
Your asking about the end that goes into the wall correct?
99% of the line cords I have seen (in the US) Have a green, white, and black wire where:
Black = Hot
White = Neutral
Green =Ground
I would suggest you use a multimeter to find which wire does what without checking it directly I would need More specifics about the laptop/power supply
Feb 20, 2009 | Computers & Internet
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
