Question about Mitsubishi WS-65909 65" Rear Projection Television
I have a mitsubishi ws-65909. We had a power outage last night. The timer light is blinking green with no response to any buttons being pushed. I have unplugged and let set for 10 min. with no results
I am a proud owner of the same TV you have. A couple of months ago, we had repeated, intentional rolling power outages in the Dallas area in an ice storm. I had the blinking green light of death also. The problem is in your DM module. If you remove the back panel on the set and expose the boards, the DM is the one farthest to the left. It is actually located inside a metal frame that surrounds it. You can disconnect the wiring harnesses coming out of it to the other boards. You may have to label the harnesses, but typically they are labeled so you can simply match the numbers of the harness removed to the receptacle into which it was originally plugged. There should be about 5 of these to remove. I recommend using needle-nose pliers, as they can be very hard to unplug. Just don't squeeze too hard and crack the plastic.
Once you have disconnected and removed the DM board assembly, you will need to remove the metal housing and disconnect another series of wiring terminals in order to fully expose the power boards within. Make sure you keep track of which screws go where, as some may be longer than others. Phone pics of wiring harnesses can come in handy so you remember where they go. After the metal housing is removed, you will see an elevated, smaller board attached to the much larger main board. The small PC board needs to be separated and removed so you can hold it in your hands and work on it. At this point, you have the option to take the board to an electronics repair shop or to fix the problem yourself (as I did) and save yourself some money. A decent repair shop should remove and replace the defective components for about $20, PARTS INCLUDED!. There are 7 capacitors that need to be replaced. They cost less than 50 cents apiece at an electronics parts supply shop. You may find them at RadioShack, but I recommend an electronics supply shop. This way you can buy capacitors that have a higher voltage rating than those originally installed. A higher voltage rating is recommended and will in no way affect performance or outcome. In fact, the original caps (capacitors) were rated too low in terms of both voltage and temperature. I believe the original caps were 1000 uf (microfarad), 16-volt caps which are black in color - indicating they are 85 degree compliant. Look for 1000 uf (microfarad) capacitors with a brown color that indicates they are better for high-temp applications of up to 105 degrees. You will be able to clearly see on the cap that it is 1000 uf, 25 v, 105 degrees C. One very important thing to note is that a defective cap isn't always obvious and will NOT always display symptoms of a bad cap. Typically a bad cap will have an outward bulge on the top, like a soda can about to explode. It may also show signs of dark, caramel or black colored syrup-like liquid oozing out of it. This should be considered, but definitely not ignored. When I fixed my set, ALL of the seven replaced caps actually looked like they were brand new and showed NO typical signs of fatigue or failure. I replaced all seven anyhow, put it all back together, and brought it back to life and saved myself many hundreds of dollars. The primary point I wish to relay is that you do not rely on the apparent physical appearance of the caps to decide their state. I hope this helps any and all with the symptoms related to the constant blinking green light which responds to nothing on the Mitsubishi WS -65909. You CAN save your TV by spending less than $75 by doing it yourself (less than $15 if you have a soldering iron and solder) or take it to a ****** who won't do component-level repairs and will just replace the whole DM board for 700 bucks or so. I know these sets are old and rapidly being replaced by LED, Plasma, and LCD sets, but you can't beat the pic for the price. If I get enough requests, I will figure out how to post a video how to to do the whole thing. I hope this helps. This will fix the constant blinking green light with no power-up on the Mitsubishi WS-65909 rear-projection TV!
Posted on Apr 08, 2011
  • Mitsubishi Master
  • 5,568 Answers
You might try pulling the plug overnight; if the power fluctuation cause some circuit to lock up, it may take a while for it to recover. If it still won't come on, the main power supply probably took a hit while the power was gyrating. Sometimes calling your electrical utility and threatening them will bring some relief; they had to replace the compressor in a fairly new refrigerator because the line voltage hovered around 25 volts for hours and burned up the motor while we were gone from home.
Posted on Mar 27, 2011
My w-65909 was turned off and plugged into a surge protector we had a power outage that night next morning went to turn it on there was a blinking green light. I unplugged it and kept it unplugged for a...
Sounds like an issue with the DM pcb. most likely some small electrolytic capacitors. you will need to remove DM pcb & take cover off. look for capacitors with bulging tops. note the values & location & replace all capacitors with bulging tops.
Feb 01, 2015 | Mitsubishi WS-65909 65" Rear Projection...
We have a rear projection Mitsubishi TV, Model # WS-55511.We had a power outage last night and when the power came on this morning, we cannot get the TV 'ON'.There is however the TIMER light on the...
Thats a very common problem caused by weak caps on the DM board when power is lost they drain and then cannot recharge when the power is restored the WS55511 DM repair kit from www.tvrepairworld.com will usually solve that issue. The kit contains the caps and the cd with instructions.
Sep 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have ws-65909 65 in TV , The power went out and now the timer light is blinking and i can not reset it.
Unplug it for 2-3 hrs. then when you turn it back on again, be sure to reset the sleep timer to "off".
Sep 08, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Timer light binking green
U have a DM problem CAPs burned out. download repair manual for your TV.
Jun 30, 2009 | Mitsubishi WS-65909 65" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi Daimond Series 65" Model#WS-65909
Most common repair is one or two open fuses in power supply
and bad convergence Ic's = expensive repair.........Also, have
the tech check for coolant leakage from CRT's...........T.
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Will not power on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Dec 09, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-65909 65" Rear Projection Television Logo
807 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
