Was playing great ,we had it turned up and stereo just shut off and just wouldn't come back on . it is a stereo w/a floor amp. hooked toit.
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 28, 2011
I wana what did i do wrong when i hook the car stereo up works great but when i shut the car off and i start it back up my stereo woulld not keep its memory can sum1 help me please
There are generally 2 power wires on a stereo. One is tied into something that only comes on when the ignition is turned on and the other must be live at all times to retain memory.
Oct 22, 2013 | 2000 Jaguar Vanden Plas
No power to stereo
fuse # 11 -15 amp43_gh329001-002.png&width=561&height=371&displaytype=display&imgrotation=&links=
Feb 03, 2013 | 1991 Ford F250
So i have installed my amp, epicenter, all wiring is done, hace great ground.. But once i turn my car on to sound check everything starts fine but after turning up the volume a bit.. My amo goes into...
It sounds like you have your gain to high. best way to solve this is by turning the gain way down to - or lowest number , then turn everything on and upto the volume you desire, then slowly up the gain. also avoid using bass boost, I agree it sounds great but it puts strain on the amp and shortens life in the amp. with the bass boost off, you can adjust others (not the gain) to get bass.
Hope this helps
Jan 26, 2013 | Car Audio & Video
Pioneer VSX-519V Multi-channel receiver won't turn on.
You could have blown the fuse in the unit, or worse still blown the output device(s) in the power amp.
Dec 30, 2017 | Pioneer Audio Players & Recorders
I have my amp and and subs hooked up right but i have multiple component wires on the back of my vm 9412. i need to know what to hook my component wires to in the back of my head unit and also need to know...
If you are running your speakers/subs from an external amp, then you wouldn't use any of the wires in the back. Usually you don't have any type of menu to change to make anything work. Some units have the ability to turn the signal off to the amp. What color are the wires in the back that you have remaining?
Apr 13, 2011 | Car Audio & Video
I have a memorex stereo, turntable, 3 cd changer etc. The standby light comes on but no sound, it is only 2 yrs old..
Sometimes you have to unplug it for about 30 seconds, then when you plug it in press the power on button. If there is still no sound, check the speaker connections on the back they sometimes come loose.
Oct 17, 2009 | Electro Brand Nostalgic Stereo CD Music...
I installed a scosche 500k micro farad capacitor in my truck. i have a 800w sony explode running a volvonhag 12" sub, the doors are run by a rockford 40i amp. sounds great till capacitor hook up. amp cuts...
You need to put the capacitor after the in line fuse/ distributor block. Because you are putting it on only your subs you are running it into fail because of a negatuve ground loop which is why they play low then cut out. Also check your grounds for both amps after rewiring and make sure they are tight.
Sep 07, 2009 | Car Audio & Video
22 people viewed this question
 Grubhead
Grubhead
