Question about Microlife 3MC1-PC Blood Pressure Monitors
When I use the unit I get a hissing noise coming from where the cuff plugs into the unit? Is this to be expected or is it affecting the accuracy of the readings.
Will tread depth of tires affect accuracy of nitestar dmi?
it will be absolute minimal and would be within the accuracy of the unit
as tread depth is around 3/8" on new tyres and is around 1/8 (legal) on worn tyres as you can see the difference is hardly worth mentioning
if the unit is measuring distance travelled then the shallower the tread depth the greater the chance of tyre slip when driving and that will affect accuracy
Jun 29, 2015 | Cars & Trucks
Have a CVS blood pressure unit BP3MU1-1E. The cuff is too large for my 95 yr. old mother. How do I get a smaller cuff? The stores have none!!
Switch to the leg. You can take the pressure on the calf or the thigh. The thigh is easier. Place the cuff closer to the knee and if the sensor can be seen on the units cuff put that under the leg close to the knee joint. Inflate as normal. The reading may be higher than you expect by 10% So if it says 140/80 it would be 126/72
Sep 21, 2014 | Health & Beauty
Air noise on 2.0 l vw
It sounds like the cat converter is badly plugged and causing major exhaust restriction--change it.
Jul 23, 2014 | Volkswagen new beetle convertible...
How to test monitor for accuracy
Best thing is to take it to your doctor and compare his readings, under the same conditions, as BP varies a lot in one person.
Feb 27, 2014 | Omron HEM 780 Automatic Blood Pressure...
My 1992 Jeep wrangler has a hissing noise coming from the back of the steering column and is having trouble shifting
Normally a hissing noise when the engine is running is a vac leak.
I'm not aware of anything behind the speedo that would be affected but you might check for vac hoses. Might be the power brake booster leaking vac but that is in the engine compartment.
Jun 25, 2012 | Cars & Trucks
Can you calibrate omron hem-711
I check the accuracy of my Omron every year. It is important that your device must give proper results.
Jun 04, 2012 | Omron Automatic Blood Pressure Monitor w/...
My Omron 711 seems to register readings that are too high when compared to doctor's office or monitors in drug stores, etc. Is there a way to check accuracy of the monitor?
Take the cuff to your doctors office and have the nurse check with yours and the office BP cuff. If your cuff is too small, you will get a false high reading.
Nov 30, 2010 | Omron HEM-711 IntelliSense Automatic Blood...
Can you calibrate omron hem-711?
Depends what you mean by calibrate. If you mean affect adjustment - no, this is not possible. If you mean test the device for accuracy, then the answer is yes. All good quality home use Blood Pressure Monitors (BPM), should meet international standards, typically this is an accuracy of +/- 3 mmHg. To have a BPM checked for accuracy you should take it to an authorised reseller. Typically this should be done every two years.
Apr 30, 2010 | Omron Automatic Blood Pressure Monitor w/...
Hiss in new fender frontman 65R. Can't seem to dial it out in either input.
A certain amount of "hiss" is present in electronic amps due to the statistical noise in electronics.
The hiss should be WELL below the level you get when playing. If you put you ear to the speaker, expect to hear some hiss with nothing plugged in. Ten feet away it should be very faint.
Dec 30, 2009 | Fender Music
Accuracy problem
Hello martintpjr, the difference could be your physical postion,(sitting,laying) location of cuff(on the fore arm), not as relaxed, cuff/tubing has a air leak,or unit is out of calibration. Eliminate the first four than contact the local college or BioMed shop in the local hospital and KINDLY ask if your unit operation/calibration could be checked. Merry Christmas.
Dec 12, 2008 | Omron Automatic Blood Pressure Monitor...
Microlife 3MC1-PC Blood Pressure Monitors Logo
108 people viewed this question
Top Microlife Health & Beauty Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Steve
Are you a Microlife Health and Beauty Expert? Answer questions, earn points and help others
