Question about Tomtom XXL 550 Car GPS Receiver
How can I charge my Tomtom GPS 550 at home using a USB to my PC ? Or can it be charged only in the Car using the Car Charger ? How long should it take to fully charge using USB & also on Car Charger ? Thanks
  • 902 Answers
I dont believe it can chagre via usb as usb only provides up to 5v of power you can buy from walmart a cheap ac to car adapter (makes your ac outlet a cig lighter adapter) and power it that way.
Posted on Mar 27, 2011
Unable to turn it on ,only lighted screen and connection ca be seen
First of all, make sure the battery is fully charged. If you're not sure your car charger is working, try charging it with a USB-cable on your PC/Mac.
Once the battery is charged, RESET your TomTom.
Old TomTom's have a RESET button on the bottom. One model has it's reset button hidden under a cover.
Newer devices don't have a reset button. You reset them by "KEEP PRESSING THE POWER BUTTON A LONG TIME"
Try pressing even more then a minute. Eventually you should hear the TomTom "Drumm Roll" (the starup sound), and your GPS would start normally.
If this doesn't work, Try updating the device firmware using a USB-cable and the right software depending your device. Older devices use TomTom HOME, never ones use TomTom MyDrive.
I wish you a lot of succes!
May 14, 2015 | Tomtom GPS
I require a mains charger for Tomtom 4n00.001. I need to charge it from home
You can buy a Tomtom main charger but they are fairly expensive.
You can use a Main powered USB charger along with your normal PC Tomtom USB cable: it should ideally be rated at 1 Amp or more.
You might even have a suitable main USB charger on hand now as they often come with generic MP3/MP4 players and some mobile phones: I use my Huawei U8150 or E585 modem charger for that purpose myself!
Hope it helps.
Sep 23, 2011 | Tomtom ONE GPS Receiver
THow to get at reset button.Tom tom not charging when plugged into 12 volt in car.
There is a small reset pin 'hole' underneath nearby the USB/Power plug.
However, if your GPS is charging when you plug it to a PC or Laptop USB port, then I would suspect that the issue is more a faulty Car Power supply/charger (could be the cable or plug if you can see the pilot light on the charger).
ps. A cheaper alternative/easier to find to an original Tomtom car charger is a generic 5V (rated at least 1 Amp) USB charger used with your Tomtom USB Cable (that is what I use myself).
Hope it helps!
May 15, 2011 | GPS
How do I charge my new tomtom?
Connect with pc via USB connection at home. (The device should be switch off.)
Use your charging adapter in a car while you are driving.
Jun 22, 2010 | Tomtom ONE GPS Receiver
I have a question concerning the tomtom 910. When plugged into the car, the tomtom goes off and on and the battery is constantly low. However,when I charge it at home, it stays on for about 4 hours. What...
Connect your TomTom to the car charger and turn it on. Tap the lower right hand cornor where the sat. signal graph is. On the screen that comes up check to see if it is chargeing while connected to the car charger. It should say charging in the upper right hand cornor where it shows the battery status. If it isn't charging then you have either a bad pin on your windsheild mount or your charger is not working. If the charger is not working it may be as simple as replacing the fuse in the charger.
Jul 19, 2009 | Tomtom GO 910 GPS Receiver
Tomtom wont charge.
If it is charging via a USB connection on your computer there is nothing wrong with the TT. It doesn't matter if you are trying to charge via USB, mains, or car charger the connection is the same for all in your TT. I would look elsewhere for the problem. More than likely your car charger is faulty.
Jun 07, 2009 | Tomtom ONE GPS Receiver
TomTom will not charge with car charger
Mine does the same, the light comes on on the charger, but not on the TomTom unit itself. There is clearly a loose connection in the cable somewhere as you can twist the flex and make it work, although this is not very reliable.
I just use a USB charger from an old phone instead.
Mar 30, 2009 | Tomtom ONE 3rd Edition GPS
How do I charge the TomTom XL 330S
You can either charge in the car, or you can use the docking station (USB cable you connect with to use TomTom Home) to charge from your computer
Dec 26, 2008 | Tomtom XL 330 Car GPS Receiver
Hi There!
You Can charge your Tomtom when you drive, or you can charge it with a USB port on your computer.
I don't think they come with a mains charger anymore?
Toby
TomTom 910 charger question
Yes, you can.
I presume the charger has an USB connector.
5v and 2A are the correct figures for a Go910.
Aug 24, 2007 | Tomtom GO 910 GPS Receiver
Tomtom XXL 550 Car GPS Receiver Logo
240 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
