Question about Troy Garden
TROY BUILT PONY- HIT A WATER VALVE EXCESS PIPE HARD. PUT ON NEW BLADES. NOW EVERY SHAKES AND RATTLES. WHAT SHOULD I LOOK FOR?
    Novelist:
  • 111 Answers
The shaft of one of the blade spindles could be bent or it could also have bent the deck. You should take it to your dealer and see if they can identify the problem as one or the other. I would ask them if it needed to be straightened or if there was a shaft that was bent. You could replace the shaft, but I would not attempt to straighten the deck. It is something that is best left to someone who does that on a regular basis.
Posted on Mar 30, 2011
Troy bilt pony riding mower
spray some carburetor cleaner in the intake and try to start it if it starts for a few seconds the carburetor is dirty and needs cleaned. put a new needle in it they are cheap and will solve your problem. take the spark plug out and try to start it. if it spins over freely and blows gas out the hole it is the needle in the carburetor. you may want to check the valves, they may be out of adjustment causing hard starting.
Jul 17, 2017 | Garden
Change blades on a lawn tractor pony? troy built
just jack it up so you can get under the deck and unscrew the bolt on center of ech blade take note on how the curves of blade are angled do one at a time incase you forget but bolt back up tight and you are ready to cut if you try to resharpen the blades make sure you balance them or they will mess up the deck bearings
Nov 02, 2010 | Troy Garden
Pull mower rope on troy built self propelled mower and it jerks it back out of your hand,hard,,and will not start
This sounds like the engine is out of time.
Usually this happens when the blades hit something hard and shears a small aluminum"key" between the crank shaft and the flywheel.
This is reparable. The little key is less than a buck. A person needs some skills to remove the flywheel to replace the "key".
Wayne
Jul 30, 2010 | Troy Garden
Where is the model # on troy built tiller
If this is a genuine Troy ... (built in Troy, New York, by Garden Way) find the information stamped on the transmission housing left or right near the tire.
May 03, 2010 | Troy-Bilt Pony Garden Tiller
Troy Built 6.0 HP stored for winter. Fired up and
Most definitely. You aren't getting enough gas, probably because the float valve is gummed up. Drain the gas, put in a little carb cleaner and a little fresh gas. Fire it up. Do that a couple of time if needed, then fill tank with fresh gas. Use a gas stabilizer like Sea Foam to prevent this.
Apr 05, 2010 | Troy-Bilt Pony Garden Tiller
Troy Built Ride-on, stalls when blade is engaged.
You may have a short in one of your safety switches. There is usually one on the seat that shuts it off if you try to get up and one on reverse if you try to back it up. I would look there to see if somehow they are grounding out
If you can get it where you can grab the blades, check and see if they float easy. You could have a seized bearing on one of your blades that is stalling out the motor as well.
Hope this helps
Aug 20, 2009 | Garden
Troy bilt pony left side tine assembly fell off
sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Apr 23, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
93 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
