Question about Danby DMW799 700 Watts Microwave Oven
Hi, My microwave, DMW799BL/W, stop working suddenly and is not responding to any control. Only thing which I could see on the electronic display is number 9 MEM. Could anyone help me out so that I could use it again.
My microwave model no DMW799Bl suddenly stopped while pressing number button, what to do
If nothing works it might be a fuse. Unless you know what you’re doing do not take it apart yourself. If you do not get it back together right it can be dangerous.
Jan 31, 2018 | Microwave Ovens
Sharp carousel microwave
You may need your main control panel repaired
Oct 21, 2013 | Microwave Ovens
Having an issue with the keypad - not responding
I would contact Samsung, they seem to be aware of the issue with the control panel failing on there otr model and are replacing them free of charge under there "epidemic warranty"
May 06, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave fuse blows during operation
to much wattage on the same line
Mar 19, 2013 | Microwave Ovens
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
Buttons not responding on nn-s235
My microwave nn- s235 have the same problem only stop botton waork but no child is displayed in the display
Jun 14, 2009 | Panasonic Microwave Ovens
My microwave panel is not working.
Sometimes if the door switches are faulty then the touch panel may not respond. There are usually 3 switches, and I'd recommend if one if faulty replacing all of them as a set. Otherwise it may be a Control Panel fault.
Mar 18, 2009 | LG LMVM2055 Convection/Microwave Oven
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Danby DMW799 700 Watts Microwave Oven Logo
89 people viewed this question
Top Danby Microwave Ovens Experts
William Miller
William Miller
vince
gbob59
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
