Question about Sharp Televison & Video
I am seeking a240volt to DC 12 volt power supply lead for a Sharp LCD colour tv (model LC-15B2UA) and an antennae lead (about three metres long) for the same unit. Could you please advise if these items are available and the cost. Thank you
    Brigadier General:
  • 6,966 Answers
On your query:
  • 240volt to DC 12 volt power supply lead > Part Number: UADP-0212CEZZ (DC 12 V, AC 110–240 V, 50/60 Hz)
  • antennae lead > antennae cable Part Number: QCNWG0003CEPA F type
Bothe are available with your regional Sharp. If in the United States, pla try:
  • 1-877-SHARP-CC (1-877-742-7722)
  • www.sharp.ca
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 04, 2008
  • 10,594 Answers
Please check required items on following website ...
http://www.shopjimmy.com/searchparts.cfm?make=Sharp
Hope it will help you out.
  • Shahid Electronics
    Shahid Electronics Aug 15, 2008
    you got DC 12 Volt supply for Sharp TV?
    Guru:
  • 1,894 Answers
The antennae cos will be low
and am not cleaqr abot your question of power supply.
can you explain your requirement in detail
Sharp tv model lc-32le340 fail to start red light remain blink.
You have verified that the power supply has failed.
Jun 17, 2016 | Sharp Televison & Video
I have a dell computer. when i turn on the tower and monitor i get just a black screen on the monitor. i have pushed a few buttons on the bottom of the screen and it just says power save mode please use...
No, it's the Power Supply.
Power Supply has a weak voltage power rail.
The monitor goes to Power Saver mode because it is not receiving a video signal. (No Signal)
This is because the computer is not working.
Dell Support > Dimension 4700 desktop computer > Service Manual,
http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
Click on the heading - Advanced Troubleshooting
Is the Power On LED light blinking Amber? (Yellow)
Post back in a Comment.
Regards,
joecoolvette
{You can also test the power coming out of the Power Supply.
The Power Supply in your computer is an SMPS.
Switched-Mode Power Supply,
http://en.wikipedia.org/wiki/Switched-mode_power_supply
It converts the AC electricity from your home, or business, into DC electricity.
There are three main voltages produced;
A) 3.3 Volts (3 point 3)
B) 5 Volts
C) 12 Volts
All are DC voltage
Two D cell flashlight batteries produce 3 Volts DC.
(In case you are worried about being shocked.
The 'bad' electricity is contained inside the Power Supply's case)
If you do not have a multimeter, an economical unit can be purchased for around $8 to $12. A LOT of stores carry them. An auto parts store is one example.
Orange wires are 3.3 Volts
Red wires are 5 Volts
Yellow wires are 12 Volts.
ALL 3.3 Volt wires end at the same 3.3 Volt power rail in the Power Supply.
Same with 5 Volt wires, and 12 Volt wires.
You can test ANY Orange wire, or any Red wire, or any Yellow wire.
ANY Black wire you see is a Ground wire.
The red probe lead of the multimeter is the Positive lead. The black probe lead is the Negative lead.
The Positive probe lead is touched to a positive wire.
Orange, Red, or Yellow.
The Negative probe lead is touched to ANY black wire. ALL black wires are a Ground wire.
The function knob on the multimeter is set to DC voltage. (Dotted line over a solid line, with a dotted line under the solid line. The curved S line over a solid line is for AC voltage. This = No)
If there are different scale settings, set the function knob to 0-50 Volts. (DC)
Aug 24, 2011 | Dell Dimension 4700 PC Desktop
Sharp LC-37D4U - Unit not power ON when power button is activated. - Main power module in located in the center has power (165V DC) and outputs 5V DC to the main processor module on the right via CN5702...
You have standby 5vdc but you need to find out if the processor board is sending out the PS_ON to the power supply to turn on the 12 and 24vdc power supply section.
Heres is the service manual and training manual for your TV.
http://elektrotanya.com/?q=showresult&megnev=Sharp%20&megnev2=LC-37G4U&kategoria=&kat2=all
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 07, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-30HV4U
replace the supply board
or repair it *** there's problem with supply
Jun 13, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Hisense TL2020 LCD TV
You should check the 12 volts capacitors on your power supply for dry or leaky, bulging conditions.
Replacing those capacitors will restore the functionality of your TV.
May 15, 2008 | Televison & Video
Antenna Power supply
First order of business is to check and see if the antenna is operating properly. If the wire in your harness is intended to power the antenna, connect 12 volts to this lead, and the antenna should go up (this needs to be done with the key in the ON or ACCY position). If the antenna does not go up, check the fusebox for a blown fuse. If the antenna does indeed go up, then you can scratch that off the list of possible problems and move on to the next step.
The Clarion should have a power input wire to keep the clock alive, and a power wire (normally of heavier guage) to actually power the radio. Make sure the radio operates when the key is in the ON or ACCY position. If the radio is operating, so far so good.
I'm kind of confused when you say there are two wires on the clarion... "power antenna turn-on" and "auto antenna". Are these both on the clarion? There should be a wire that constantly feeds the antenna with power (I would cal this one auto antenna). It should always be powered to 12 volts. The antenna should operate when the "antenna turn on" lead becomes 12 volts. Normally this ONLY happens when the clarion RADIO is on (ie: if you're listening to a CD, the antenna probably won't get activated).
After checking all this, if you're still having problems and if you haven't already done so, grab a DC volt meter and verify that the clarion power antenna turn on lead goes to 12 volts when you turn on the radio. If it does not, then there is an internal problem within the radio. If this lead IS going to 12 volts when it is supposed to and the antenna still isn't working, then my guess is that the antenna is malfunctioning.
Let me know what you find out... I'll keep looking at stuff from this end. Good luck.
Apr 19, 2008 | Clarion DB175MP CD Player
Installing tv in boat
You can But I would not connect it directly unless I had a regulator or isolation device between the set and the boats power. if your boat has 110 volt capability just be safe and use the adaptor.
Sep 15, 2006 | Sharp Aquos LC-15S1U-S 15 in. EDTV-Ready...
Televison & Video Logo
64 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
