Question about Hardware & Accessories
THE CLOCK IS ON A LA CROSSE WEATHER STATION WITH NO INSTRUCTIONS WHAT DO I DO?
    Novelist:
  • 157 Answers
Hello. Not certain what you are trying to do with the clock, so I have attached the link to the company's list of manuals. Simply select the make and model you have, and the information should help you. Failing that, the company does have a contact page, and I am certain they will be able to assist. Good luck.
If this has helped, please rate it a four thumbs up. Thank You.
http://lacrossetechnology.com/support/manuals.php
Posted on Mar 29, 2011
Testimonial: "spot on, many thanks"
I wat to connect a idevworks surf station 8.0server
Posted on Apr 06, 2011
Need manual for la crosse weather station model: WS - 1612 - 11
https://www.manualslib.com/manual/91064/La-Crosse-Technology-Ws-1612.html
Oct 25, 2017 | La Crosse Measuring Tools & Sensors
New la crosse technology wind speed weather station model # CA87092 set up.wind speed and outdoor temperature showed until this morning.new batteries used yesterday in setup. what is the problem?
The instructions for your station call for a specific set up procedure. Batteries should be installed in the transmitter first with time allowed for it to initialize and begin sending data. After installing batteries in the receiver, you should see wind speed and temperature displayed. BUT, here in the real world I have a Lacrosse receiver currently displaying a balmy 67 degrees inside and a not-so-balmy - - outside. I believe the alkaline batteries used in the transmitter lose efficiency or freeze at low temperatures. Warmer weather restores the outside temperature display.
Jan 05, 2017 | La Crosse Measuring Tools & Sensors
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
My remote sensor Tx14TH-LCD-B started flashing several days ago and I have gone thru the factory reset new batteries and decided to buy a new sensor then discovered they have been discontinued along with...
I assume you have tried removing the batteries at both ends, reinstalling batteries at the sensor end then the indoor end, waiting without touching anything until the outdoor temp registers and heaving a sigh of relief as things are back to normal. I also assume since the word atomic is in the header that you have an atomic clock function. If nothing works or doesn't work right you probably need to replace the system.
I have a much simpler LaCrosse system which, at this moment, is showing an outside temp of 56 degrees BUT the clock doesn't work and failed early on. I share your frustration.
Nov 04, 2013 | La Crosse Technology La Crosse S98642...
My outside temperature and humidity sensor appears to have failed. I'd like to buy a replacement. 433 MHz. The system is WS-7395U. Please advise price. taylor.norman1@gmail.
The WS-7395U uses the La Crosse TX8U outdoor temperature and humidity sensor. That part has a $49.99 MSRP. It is $46.95 from La Crosse; see http://www.lacrossetechnology.com/tx8/index.php to order the part. Other vendors that I checked do not have the sensor in stock for sale separately.
I hope this helps.
Aug 21, 2013 | La Crosse Technology La Crosse C86234...
I need a user guide for a La Crosse WS-9211 Weather Station clock
Solved it! La Crosse let you download manuals from their website.
Nov 23, 2008 | La Crosse Technology E. Howard Ambassador...
Hardware & Accessories Logo
696 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
