Yes, i am having ps3 motherboard problem. It seems to work from 2-1/2 to 4 hrs then it will freeze game and start to see blue purple green colors run from corners of tv into center til it floods tv then freezes console. I have replaced compound with AS5 several times.Is this a board issue or jus my processors not cooling properly?
  • 822 Answers
Could be either..........you could try sitting machine on a laptop cooling fan board..............
cheers
Posted on Mar 27, 2011
    President:
  • 1,623 Answers
Are you using onboard graphics or a slot in graphics card?
Vga wiring i want to know what each coler wire represents so i wont burn my pc wiring my stuff into it
Here's some wiring diagrams:
First according to pin: http://hot-flash-games.com/web/vga%20cable%20pin%20connection-2875.html
And in this post you have pinouts according to standard color: http://www.diyaudio.com/forums/diy-projectors/30458-vga-pinout-wire-colors.html
db15 male
1)brown
2)red
3)orange
4)salmon
5)yellow
6)dark green
7)light green
8)dark blue
9)NC
10)light blue
11) purple
12)grey
13)white
14)black
15)brown/black
DB15 Female
7)light green
2)red
11)purple
13)white
1)brown
6)darkgreen
8)dark blue
10)light blue
3)orange
that's all oh yes you also have a ground wire from connector base to connector base.
Hope this helps. So from these two, you should be able to figure out witch wire is witch. Let me know if you need more detailed information.
May 03, 2011 | VIA ASUS A8V-E Deluxe K8T890 chipset...
My Sony DVD player is only showing colors in green and purple hues. Could it be a connection problem?
Yes. Could be the color signal jacks in the back. Make sure you have them plugged in properly, green for green, blue for blue, and red for red.
Jan 06, 2011 | Sony Televison & Video
My ps3 shows a green lite then orange and stops whats wrong ?
This could mean there is a problem with adequate power towards the Motherboard within. Incandescent LED's/Light Emitting Diode's: used as colorful indicators, and often appear green, blue, red, etc... are sometimes bi~color, (that means 3 terminals per LED). This could be a power board problem. Maybe, try to Take to service Technician to analyze if its the Power board.
Apr 02, 2010 | Sony Playstation 3 (PS3) Console
I need to know what color the ignition wire is so i can install a kill switch on my 06 F250 Powerstroke
hi, hope this will help.....if it does, could you leave a positive feedback for me please...many thanx..........
PART COLOR LOCATION
12 VOLT CONSTANT BLUE/RED (+) IGNITION SWITCH HARNESS
STARTER BLUE/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A N/A
IGNITION 1 WHITE/ORANGE (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A N/A
IGNITION 3 N/A N/A
ACCESSORY/HEATER BLOWER 1 BROWN/YELLOW (+) IGN SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 PURPLE/GREEN (+) IGN SWITCH HARNESS
KEYSENSE BLUE/GRAY (+) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) GRAY (-) AT HEADLIGHT SWITCH
PARKING LIGHTS ( + ) PURPLE/WHITE (+) SMART JUNCTION BOX IN PASSENGER KICK PANEL
POWER LOCK BLUE/LIGHT GREEN (-) TYPE (B) IN DRIVERS KICK PANEL
POWER UNLOCK YELLOW/PURPLE (-) TYPE (B) IN DRIVERS KICK PANEL
DOOR TRIGGER VIOLET(+) UNDER DRIVERS SILL IN HARNESS COMING FROM PASS SIDE
DOMELIGHT SUPERVISION GREEN/BLUE (-) HEADLIGHT SWITCH
HORN YELLOW/RED (-) AT STEERING COLUMN HARNESS
TACH BLUE(AC) AT HARNESS NEXT TO BRAKE PEDAL
WAIT TO START LIGHT N/A N/A
BRAKE PURPLE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
ANTI-THEFT TRANSPONDER ANTI-THEFT TRANSPONDER @ IGNITION SWITCH TUMBLER
Aug 05, 2009 | Ford Super Duty Cars & Trucks
Console freezing in main menu after a min green and red dots
do not perform fan test not good for unit. use vacume to clean out unit. if it was the motherboard it wouldnt turn on at all.
Jun 01, 2009 | Sony PlayStation® 3 (60 GB) Console
Freezes on startup
just call sony and talk to an operator and they'll send u a box to send your consule to them. You'll need your receipt though.
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
SONY PS3 80 GB GOT BEER IN IT
You my friend have fried the motherboard!!!! Only way to get that baby out is to take the ps3 apart then take the blue ray player apart.. its a long process and you could actually break all of the ps3!.. I can help you out if you want but its no easy task and you had better be ready to spend a few hrs on it at least!
I do buy ps3's and would be more then happy to purchase your fried system and return your games! Let me know!
May 24, 2008 | Sony Playstation 3 (PS3) Console
My ps3 won't load any games
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Mar 11, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
