Question about Grilling
Hi! Hope you can help us--we have a Brinkman 4-burner grill that is about 5yrs. old. Last yr. we started having problems with burner #2 not lighting all of the way and the burners all looked a bit rusty, so we ordered new burners. Well, after replacing all of the burners we now have NO flame from burner #2 at all (& burner #1 does not get as high of a flame as #3 or #4, even if it is the only burner turned on). My husband tried blowing air & pushing a wire through the venturi tube but it feels like something harder than metal is blocking it. I guess my questions are: 1) Can a spider web get this hard? 2) If so, what do you use to get it out? 3) Can the entire venturi tube be replaced? (my husband said it looks like there would be no way to remove this part, at least that he can see). Thanks for any suggestions--we spent close to $400 on this grill and planned on having it for alot longer than this!
    Brigadier General:
  • 4,736 Answers
I think you husband is trying to clean the wrong thin. The venturi tube is part of the burner itself. It's the open end of the burner, that has an air intake adjustment on it. It fits over the burner orifice. He may be hitting the orifice, which in fact may be clogged. Remove the offending burners and he will be able to see the burner orifice, which can be removed with the appropriately sized wrench. Once removed try blowing through it. If air doesn't blow through, it's clogged. Clean it with a straight pin that is no larger that the orifice hole. You do not want to enlarge it. Also, the new burners may need adjustment of the venturi for the proper air to gas mixture. Consult you Owners Manual on how to adjust it.
Need an Owners Manual? Go to http://www.brinkmann.net/my_grill.aspx and enter the Model Number of your grill.
Hope this helped you to solve the problem. Please don't forget to rate my response to you. Thanks!
Posted on Mar 28, 2011
Testimonial: "We haven't tried this yet, due to the weather but we definately didn't know that the venturi tubes come out. Will try & let you know. Thanks!"
Looking for a brinkmann 810-3200G replacement burner
Unfortunately, your model grill has been discontinued by Brinkman. The burner you need, Part # 19810-3200-G is no longer available and there is no substitution.. Neither from Brinkman or other grill part sources. In fact, the only 2 parts available from Brinkman for you grill are an ignitor button & cooking grates.
I'm sorry, I wish I had better news for you. Thanks for choosing FixYa.
Jul 27, 2011 | Brinkmann Grill King Deluxe 810 3200-0
MY SMOKER WONT LIGHT. I HAVE TRIED TO PURGE THE GAS AND USE A MATCH TO LIGHT THE ELEMENT. SEEMS LIKE THERE IS NO GAS MAKING IT TO THE SMOKER. THE GRILL IS BRAND NEW AND THE TECH SUPPORT AT BRINKMAN I KEEP...
The problem lies in the gas regulator and the way the tank was turned ON. To solve the problem, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes abd reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is full open open trun the gas valve on to the burner and light it. Did the burner
light and does the flame height look correct? If so, you solved the problem.
If the above didn't solve the problem, you will beed to replace the Hose/Regulator Assembly, as the regulator is permanently locked up. You can pick one up at any hardware store or home center that sells grills and accesories for about $30.00. Take your old one with you for comparison purposes. Unfortunately, it is not a warranty issue. As the new OPD Valve tanks cause this problem, if the tank valve is opened to quickly. So from now on, open the valve Very, Very Slowly.
Hope this helped you. Please let me know.
Jul 13, 2011 | Brinkmann 5 Burner with Smoker 8101750S
Brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
2. Wait 5 minutes and reconnect the hose to the tank.
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 04, 2011 | Brinkmann Grilling
Periodicly I won'y be able to get the grill temp to over 200 degrees. sometimes it is ok and can reach as high as 500 degrees other times it will just not generate enough heat to grill.This is a five...
zonfish - if you're tuning the gas tank off at each use, as you should. The problem lies in your grill's gas regulator, but it also is not a big deal and is easily solved.
Whenever, you open the tank valve, do it VERY, VERY, SLOWLY (Slow Motion, slow), until it is fully open. Then light the burners.
What happens is this, LP Gas Grill Tanks are now equipped with an Overfill Protection Device ("OPD"). And often time, when you turn the valve on like you would normally do, the OPD Valve sends a hot load of gas to your grill's regulator and partially locks it up or locks up entirely. Therefore, the burners are not getting enough gas to heat the unit up to 500 degrees. Opening the valve very, very, slowly, overcomes this problem.
I hope this helped you and Happy Grilling.
Jun 20, 2011 | Brinkmann 810-2300-B Grill
When pressing igniter switch - hear a pop like gas is going to light but no flame appears. Used the central knob as stated. Also tried manual method using end knob. Nothing happened. Brinkman model...
If you're using a 20 Lb Propane grill tank, here's what you need to do.
1. Turn the tank valve OFF.
2. Disconnect the hose from the tank and wait 5 minutes.
3. Reconnect the hose to the tank and open the tank valve VERY, VERY SLOWLY (Slow motion,
slow).
4. Once the valve is fully open, light the burner farthest from the tank first and turn it to HIGH.
Did the burner light and the flame looks normal? If so, light the remaining burners the same way.
Did all the burners light and all the flame heights look normal? If so, you solve the problem.
Always remember to turn the tank valve on very, very slowly. If that did not solve the problem, remove and clean all the burners and each burner's venturi valve. Spiders love to build nest in them.
iIf cleaning the burners and venturi valvesdidn't solve the problem, you will need to replace the Grill's Hose/Regulator Assembly. You can get one at any home center or hardware store that sells gas grills and accessories for about $30.00. Take your old one with you for comparison purposes.
Hope all this helped you to troubleshoot and solve the problem. Please let me know. Happy Grilling!!
Jun 13, 2011 | Brinkmann Grilling
Brinkman gas grill won't start. Don't hear clicking sound. Hooked up new gas tank, but no success
Victor, are you sure you're getting gas to the burners after installing the new tank? You can try match lighting them to make sure. But, I suspect, that it's the installation of the new tank, that's causing the problem.
To test my theory, tune the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Ope the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, try lighting the burner that's farthest from the tank first and turn it to high. Did the burner light and does the flame height look correct? If so, light the remaining 3 main burners the same way. Did those burners light and the flame heights looks correct? If, so you solved the problem. Remember to always turn the tank valve ON VERY, VERY SLOWLY.
Hope this helped you solve the problem. Happy Grilling.
Jun 01, 2011 | Brinkmann 810-8410-S Stainless Steel...
BOUGHT A BRINKMANN 2545 GRILL LAST NIGHT. WE HAVE IT ATTACHED TO GAS LINE COMING FROM HOUSE. GRILL WILL LIGHT BUT IT IS A LITTLR FLAME AND THE OTHER BURNERS WILL NOT LIGHT?
If you have a high pressure 2lb LP Gas System feeding your house, you will need and inline regulator for you grill.
If you have Natural Gas, the grill will have to be converted to Natural Gas. You can do this by changing burner orifices. You can purchase them from Brinkman. That is, if Brinkman approves the change to Natural Gas. Some gas grills aren't convertible.
Feb 09, 2011 | Brinkmann Grilling
Char Broil commercial grill won't heat pass 300 degrees
I had a similar problem and thought the propane kept running out....come to find out it was a defective regulator. $21 at the local ACE store as running to LOWES and trying to get a point across to a 17 yr old summer help college kid for a intermittent problem seemed more challenging then it was worth. Would barely light the burners and would not get over 200 degrees. Ripped it apart...blew through all the orfices including the regulator put it all back together and would work for a while then fail again. Good luck!
May 30, 2008 | Char-Broil Commercial Stainless Steel...
Grilling Logo
357 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
